Hot Rods 32 Ford roadster quarter panel Brackets
Discussion in 'The Hokey Ass Message Board' started by Art Center Dropout, Apr 5, 2019.
  1. Did all 32 Ford coupes and roadsters come equipped with both front and rear quarter panel braces? My roadster has the front braces but no rear braces. I do not intend to use a rumble seat, so are the rear braces needed ? Any help will be appreciated.
  2. FritzJr
    FritzJr
    All 5-window coupes had both braces, regardless of whether they had a rumble seat or trunk. I ***ume that this was also true for roadsters
  3. My car was channeled and they must have been removed at some point. Thanks
  4. alchemy
    alchemy
    Can you see the old rivet spots?
  5. krylon32
    krylon32
    from Nebraska
    I've always replaced the missing rear ones as I felt they added some support between the subrails and the 1/4?
  6. Just checked and actually the rivets are still there.
  7. That was my thought also.
  8. swifty
    swifty
    United Pacific sell them for the 5 window coupes so you could use them for your roadster.
  9. Looks like Speedway has them on sale with free shipping. Brooksville has been awfully proud of their prices lately.
  10. alchemy
    alchemy
    Be aware that the tail panel on coupes is different height than roadsters. So, the decklid is probably slightly different height as well. So does that make the braces a different part as well? You might be better off buying roadster parts in case coupes don't fit right. Maybe it doesn't matter if you aren't intending to install a rumble though.
  11. swifty
    swifty
    I didn't realise there was a difference between 5w coupes and roadsters, sorry if I'm giving the OP wrong info.
    guess you could check the part # between Brookville and UPAC.
  12. deucendude
    deucendude
    from norcal
    I don't think there would much difference in either one. A minor cost compared to building a car. Just get ones made for a roadster.
  13. Thanks for the info Guys. I spoke with Union Pacific and the coupe brace does not fit the roadster, so it will be Brooksville. Rebuilding a channeled car into a hi-boy is like a jigsaw puzzle. I now seem to have a bunch of 4 dr. ,2 dr. and 5 w coupe bits and pcs., but threads like the Template Roadster are helping. Thanks again!
