32 ford spring
Discussion in 'The Hokey Ass Message Board' started by woodiejon, Nov 10, 2011.
  1. woodiejon
    woodiejon
    Hi, Will a stock 32 ford rear spring fit a 40 ford rear end ?
  2. racemad55
    racemad55
    no,32 spring is curved,40 is straight
  3. chopt top kid
    chopt top kid
    Only if you're using the matching '32 Ford rear crossmember. The '32 spring won't work in a stock '40 crossmember and a '40 spring won't work in a stock '32 crossmember... Either spring will bolt up to the spring perches on a '40 rear axle...
  4. lowsquire
    lowsquire
    from Austin, TX
    different installed width as well.
  5. chopper cliff
    chopper cliff
    from lodi ca
    32-34 has curved spring, you will have to angle the 40 spring hangers to match, so you wont put a strain on the schakels other than that, they will work, with 32 crossmember I just put an A spring on a 34 axel and adjusted the offset hangers to match. works good
