Technical 32 Ford Steering Box Dilema
Discussion in 'The Hokey Ass Message Board' started by Nacifan, May 14, 2025.
  1. Nacifan
    Nacifan
    Hey Guyz,
    Is there a bolt on Steering box for a 32 Ford that looks the part and works better ??
    I have Vern Tardels Book, truly a big help. My reading is even new they weren't "all that good"
    I know I can rebuild this one if it's "gears" are not too worn. Just looking for something better ??
    I'm trying to help out a friend with a restored more-door "banger".
    thnx,
    NaCifan
    porkshop likes this.
  2. alchemy
    alchemy
    @NealinCA can get you the best one around.
    51 mercules and 51504bat like this.
  3. Hitchhiker
    Hitchhiker
    Either get Neal's steering box or alternatively ....go drive a model A. Preferably a 28-29 and then the 32 steering box won't be so bad.
  4. Fogger
    Fogger
    There is not a better replacement steering box than Neal's. If the issue is the cost start saving for it. I tried every trick to rebuild my original '32 box, '34 ratio, seals, bearings, etc. I still wasn't satisfied with the results. Neal's steering box is the answer if you want a direct bolt in replacement. The old adage of doing it once is still valid.
    porkshop and Algoma56 like this.
  5. Nacifan
    Nacifan
    dare eye ask the cost ???
  6. Fogger
    Fogger
    Contact. NealinCa for price and availability
  7. krylon32
    krylon32
    from Nebraska
    Another vote for Neal. Used 2 and they were perfect.
  8. I tink they run a little under 1k, best to contact him and verify. Keep in mind this for a brand new made in USA part with a good reputation around these parts.
  9. krylon32
    krylon32
    from Nebraska
    Better up the anti. A new NHRP Nash/Hudson style repro steering box with column built to be a bolt in for your 32 Ford will scare the hell out of $2500. There's usually a waiting list. He can also set them up to use your stock switches.
  10. Nacifan
    Nacifan
    Thnx PockeNick, Krylon32
    I just heard back form Neal :) His box is a work of ART !!!!
    pprather likes this.
