Technical 32 Ford swing out window
Discussion in 'Traditional Hot Rods' started by gypsy, Feb 13, 2022.
  1. gypsy
    gypsy
    from florida
    I need detailed pictures of a 1932 Ford swing out window mechanism, studs, mounts, brackets, slides, etc. How the whole mechanism is ***embled and how it operates. Thanks
  2. redo32
    redo32
    Do you mean windsheild?
  3. alchemy
    alchemy
    What body style? There a few different styles and the mechanisms are slightly different on each.
  4. gypsy
    gypsy
    from florida
    It's a coupe, front windshield, thanks
  5. alchemy
    alchemy
    Like I said, what kind? A 5-window is different than a 3-window.
    https://cwmoss.com/collections/windshield/1932
    Check that page for a good representation of the hinges, and the frames. They don't interchange. I don't think the slide arms even interchange. Maybe the knurled nuts on the slide arms might interchange.
    lurker mick and lothiandon1940 like this.
  6. redo32
    redo32
    There's an old thread on here for mounting a stock windshield in a gl*** Vicky.
    dana barlow likes this.
  7. Junk yard
    Junk yard
    from Paltucky
    If you know the thread would please share .
    Lockjaw and rbrewer like this.
  8. redo32
    redo32
  9. ekimneirbo
    ekimneirbo
    Ever had an engine boil over when the windshield is open ? I have..............o_O
    studebaker46 likes this.
  10. HOTRODPRIMER
    HOTRODPRIMER
    5/16"-24 Thread Pitch, 3/8"-24 Thread
    HRP
    tr_rodder, rdscotty and deuceman32 like this.
  11. nochop
    nochop
    from norcal
    I’ve had mine slam shut……at 70…..live and learn
  12. HOTRODPRIMER
    HOTRODPRIMER
    I have never driven my old beater with te windshield open but have driven thousands of miles with the vent open. HRP
    Fogger and Junk yard like this.
  13. clem
    clem
    I thought he meant the thread on the HAMB ?
    is that for the windshield slide arm bracket ?
    tr_rodder likes this.
  14. HOTRODPRIMER
    HOTRODPRIMER
    My bad. HRP
  15. clem
    clem
    ^^^^^^ not at all , actually that is something I wanted to know anyway. Thanks.
  16. gypsy
    gypsy
    from florida
    It's a 5 window coupe, would like a picture of the complete mechanism, thanks
  17. swifty
    swifty
    Is your coupe gl*** or steel and if steel, original Henry or UPAC? I just installed the windshield in my UPAC 32-5W (unchopped) and my gl*** guy (in his 80's) said to pull it as tight as possible and don't open it cos if you do you'll have leaks forever. And he has been driving a 32-5W since 1973. I can take pics of mine if you want but I'm not opening it LOL
  18. gypsy
    gypsy
    from florida
    It's an original Henry 5 window, just got an original windshield frame, but all of the hardware for the windshield swing out mechanism is missing, any pictures will help. Thanks
  19. Fordors
    Fordors
    76978208-34F9-4C5D-8A77-A52580620F75.jpeg 74C020CA-BAEF-40F7-8290-B1CD48D770B0.jpeg F81EA8FF-CA91-4B50-9B20-046DE2477A83.jpeg BDABFB82-AA7A-4F49-BDC9-D3BED2E1EED9.jpeg FEC9C715-2D6B-4A41-9773-7D55EF29D72A.jpeg DEF80719-6C28-456C-9074-601BDFCA188F.jpeg
    First photo is hinge on body above windshield opening, second is the stud for the swing arm. The bracket for the stud is held to the A pillar with three rivets. Third and fourth photos show the w/s half of the hinge and the swing arm bracket. Next photo shows the keeper to hold the w/s open, the thumb wheel tightens against the keeper to hold the w/s either closed or open. Last photo is from the thread mentioned above, it shows the items ***embled.
    I should have mentioned the swing arm pivot, it’s above the keeper and thumb wheel.
    lothiandon1940 likes this.
  20. swifty
    swifty
    There you go @gypsy @Fordors has provided all the pics and info that you will need. Note also on your OG windshield frame you cannot remove your top hinge brackets as for some reason they have 3 screws plus a couple of spot welds.
  21. redo32
    redo32
    Looks like all the parts in the picture I posted 2 days ago.
    Anderson likes this.
  22. Fordors
    Fordors
    Post #18 asked for help and that is what I provided.
    Jeff Norwell likes this.
  23. gypsy
    gypsy
    from florida
    Thanks guys, you've been a huge help.
