Hot Rods 32 ford tank venting
Discussion in 'The Hokey Ass Message Board' started by nochop, Sep 17, 2025.
  1. nochop
    nochop
    from norcal
    My original tank is going to get pulled and turned into wall art. I believe the 30 year old coating is giving up and actually making it through the filter. Bought a new Tanks inc unit that includes a rollover/vent valve. Any ideas on mounting the roll over vent? I haven’t started the change yet, just spitballing. Thanks all
  2. Bandit Billy
    Bandit Billy
    They say the vent should be higher or as high as the filler (the tank fill not the guy manning the pump handle). :cool:
    That is tough on a 32 tank where the fill is directly on the tank. I would run the vent up the back of the tank, under the body, maybe to the crossmember? Out of sight.
    nochop and 5window like this.
  3. clem
    clem
    this is what is required in New Zealand.
    51 mercules, 5window and Kiwi 4d like this.
  4. clem
    clem
  5. 19Eddy30
    19Eddy30
    from VA
    I ran mine around lip of tank to rear spreader bar under frame horn cover.
    No roll over used .
    nochop likes this.
  6. alchemy
    alchemy
    Doesn’t the rollover ball negate the need to loop the vent up high? If you roll the car, the ball stops the leak.
    I’ve had a Tanks rollover valve/vent on the stock tank in my 32 sedan for almost 20 years. No fumes. But I’ve never rolled the car, so I can’t tell how it would work in a crash.
    UNCLECHET, 19Eddy30 and 5window like this.
  7. 5window
    5window
    Rollover vents are a good idea.
    Federal safety and environmental regulations
    • Fuel system integrity (FMVSS 301): The National Highway Traffic Safety Administration (NHTSA) mandates that vehicle fuel systems must withstand crashes without significant fuel leakage. In a rollover test, fuel spillage is strictly limited during the first five minutes and subsequent increments of rotation. Rollover valves are a key component in meeting these standards by closing the vent line to prevent fuel from escaping when the tank is not upright.
    • Fuel system venting (49 CFR 393.65): The Federal Motor Carrier Safety Administration (FMCSA) also has specific requirements for liquid fuel tanks, including those over 25 gallons.
      • Safety venting system: Tanks must have a venting system to prevent ruptures in case of fire.
      • Air vent: All fuel tanks must have a non-spill air vent, which can be part of the fill cap or a separate unit. This prevents vacuum lock and allows for proper air displacement.
    • Clean Air Act: Capping or byp***ing a rollover valve is a violation of the Clean Air Act, as it allows fuel vapors and liquid fuel to be released into the environment.
  8. 19Eddy30
    19Eddy30
    from VA
    All above can be Debunked
    Just One Thought ,
    Big Trucks side saddle tank typical 125 gallons,
    My Big Nose Pete
    Had 2 150gallon plus a snigle 100 gal
    So 400 gal's . All 3 tanks Aluminum.
    Quite frequently big trucks get
    T-bone / hit in the tanks,
    Back in 70's Vega /Pinto all big Media scare, Fire
    & up to around 74 gas tank in cab of truck behined seat.
    Someting to thank about ,
    All vehicle with all the plastic
    There a lot of "Static Electricity"
    Then Most Run there tanks Low
    Then pump Gas , Most of us know
    Fume's are more dangerous than the liquid,,
    For like last 25 years I make a Habit to ground my self out when Exiting plastic Vehicles & befor pumping gas.
    Back in 90 NHRA started a Rule that
    Nylon fuel cells Needed to be Grounded. & when we picked up Fuel @ air port 100 blue , we grounded
    Jug /Vehicle just like when fueling a Plane
  9. Mr48chev
    I've pondered that before when someone was trying to figure it out but I'd say the barbed roll over valve in a loop like Clem showed in post 3 with some creative tube bending and a couple of gromets foor the holes at the back of the of the trunk floor right above the vent tube just in front of the back panel Screenshot 2025-09-18 100551.png Screenshot (906).png Screenshot (907).png . I'd stick some sort of filter on the bottom of the loop if it were mine even if it was an inline fuel filter to keep any dirt out.
  10. clem
    clem
    with a ‘32 as the original poster is asking about, everything is outside of the body.
    No need for grommets going through the trunk floor.
    If you are alluding to a fuel tank in the trunk, New Zealand’s lvvta has a diagram for that also,
    maybe of help to someone….
    5window likes this.
  11. nochop
    nochop
    from norcal
    You a wise guy Billy lol
    Bandit Billy likes this.
  12. nochop
    nochop
    from norcal
    Where did you terminate it, I’m thinking up above the rear axel is about as hi as I can get it
  13. nochop
    nochop
    from norcal
    What tanks inc told me is the roll over valve takes the place of a vented cap which can leak gas slosh. The roll over vent needs to be higher than full fuel level. I’m ***uming that if there is a loop i.e. a line lower than the terminal placement of the roll over, would not vent how I’m intending the valve to function (as a vent)
  14. nochop
    nochop
    from norcal
    No splash out the vent? Odors? Vented or non vented cap?
  15. alchemy
    alchemy
    325w and nochop like this.
  16. 19Eddy30
    19Eddy30
    from VA
    No , & I drag my cars
    I had a Model A with 32 tank I made
    Work my own set up ,
    & other 32's
    14 gallon tanks
    All 3 where / are low 6 sec 1/8 .
    In if you run vet under or up threw
    Trunk , Fumes / gas smell in side car's
    The A No frame horn cover , So I drilled hole in boxed frame
    ( adaptor to stock boxed A frame)
    , & ran Nylon hose / tube in frame back to rear
    Spreader bar 7/16 th I D
    nochop likes this.
  17. 5window
    5window
    You're allowed more than 60 characters in a line. It might make it easier to read. :)
    mkubacak likes this.
  18. RockyMtnWay
    RockyMtnWay
    Here’s a couple examples of how I do it.
    One example (puppy) is in a Tudor, and one is a Roadster (did a 5Ws same way).
    Both use a pricey rollover valve in-line and then a small filter at the end of the line (under the floor).
    note: didn’t put the coil in the line (in the 5W) and it still seemed to work. It was more like the tudor line. Don’t know why I did it this time, but always experimenting. :D:D:D
  19. Bandit Billy
    Bandit Billy
    Cute puppy. Looks like a great garage buddy
  20. 5window
    5window
    Keep the antifreeze cleaned up and locked away.
  21. Karl Wescott
    Karl Wescott
    This is basically what I did on my roadster, get the vent as high as possible. The one other thing I did was to put a cheapo in line filter on the end of the vent line in the theory that it would help minimize any road grit getting into the tank.
  22. pprather
    pprather
    Mine comes up through the floor in the right fender well (behind the upholstery panel) about 6 inches, then a 180 degree bend and down through the floor to the atmosphere.
