Technical 32 Ford windshield frames
Discussion in 'The Hokey Ass Message Board' started by alchemy, Jan 20, 2025.
  1. alchemy
    alchemy
    Actually for my Dad’s car, and he’s got a place in Minnesota that will be doing the chrome. Not sure of the name.
  2. dirt car
    dirt car
    from nebraska
    David on the Ford Barn wrote the book on 32 restorations, contends the N/C co. in Pennsylvania has the best contours & fit.
  3. dirt car
    dirt car
    from nebraska
    My correction, the N/C industries in Sayre Pa. 570-888-1821 Bob Petrushek is the contact & makes the windshield frames closed body 5w & sedans raw steel $600 & sprt cpe./b-400 $630 plating $400 up charge, will begin a new supply in Feb. I did inquire with regards to S.S. & he said the material is not forgiving enough & cracks when fed into the dies.
    Montana1 likes this.
  4. dirt car
    dirt car
    from nebraska
    An interesting note from Bob at N/C Industries, the bubbling on an old, revived frame when plated is ***ociated with the deep pitting within the confines of the frame, unseen & can often be so near the surface the acid dip to remove the rust in the prep operation generates a paper-thin exposed surface & ultimately bubbles the chrome plating. He has aways suggested to opt. for new material when plating & paint only on the revived frames to save the wallet.
    teach'm and Montana1 like this.
  5. clem
    clem
    I have never seen one done in stainless.
    (although I did consider making my own and if going this way, stainless would be the preferred choice over mild steel).
  6. Beanscoot
    Beanscoot
    Maybe one of the vendors can try to make 'em out of copper nickel. Malleable and strong, it polishes up like nickel plating, and slowly tarnishes to a dull copper colour:
  7. dirt car
    dirt car
    from nebraska
    Aluminum stock is extruded in a variety of shapes & configurations & I believe several examples are currently available but not certain if made from welded flat stock or extrusions, no clue regarding quality of fit & finish, nor if hinged swing out or only fixed examples are available. A big plus of course is raw or polished could save the $ or even plated if so desired. I neglected to inquire if N/C Industries equipment could manufacture aluminum examples, might be worth a phone call.
  8. Joel W
    Joel W
    I have noticed UP makes parts for semis also. Suspect that that is what Safety Supply mainly sells. Proceed with caution- but I am interested too. I don't think they actually have them in stock though...
  9. dirt car
    dirt car
    from nebraska
    Not sure if UPI & Safety Supply are joined at the hip, however I believe they do in fact share products on each other's web sites
  10. dirt car
    dirt car
    from nebraska
    A bit off topic but curious to know if anyone has used the Mr. Roadster P.U. aluminum frame? The Speedway Motors web site lacks quality photos & show what appears to be 45 degree unwelded corners all around with the top hinge area removeable for gl*** installation while the original steel Ford units had welded & finished bottom corners. also wondering with regards to fit, finish & how well the body to frame gasket fits
