Technical 32 frame front/rear bars
Discussion in 'Traditional Hot Rods' started by 3w Hank, Jan 25, 2023.
  1. 3w Hank
    3w Hank
    I building a traditional late 40’s 32 coupe.
    I has bougt a curved front ( A-Ford brake bar ) but I has not got it yet ( bought in USA ) so what is the diameter on thoose and a std 32 front bar ?
    Should one use bolt/nut or thread the plate ?
    I ask since holes on frame distance is only 1.82” so bar diameter and nuts.
    At rear, what is the diameter that is common used ( I use std 32 tank )
    It’s time to cut the std rear cross and install a A-Ford cross and see that rear tires match the body, so I need install the rear bar for mock-up.
  2. Atwater Mike
    Atwater Mike
    Crazy thing happened to my '32 front and rear spreader bars. I bought a Deuce Factory frame with f. & r. spreaders, my Australian bud was in Long Beach, 550 miles South of me. He had a car trailer, so was to stop in Stanton (at the Deuce Ranch) and pick them up to bring them to me.
    We unloaded the rails, (they were together wrapped) and Rob went on to pick up some cars to take back to O-Z. (Australia) 2 weeks later, he was back (Australia) and called me. The spreader bars were tucked in some of his stuff and went back to O-Z with him!
    I didn't really need 'em, my Deuce rails went under my narrow '27 T...
    So, that's why I don't have those numbers!
    Tman likes this.
  3. krylon32
    krylon32
    from Nebraska
    The front spreader is normally 1.75 in diameter and the rear spreader is normally 2 inches. Those are the diameters of the spreader bars I have worked with since I built my first deuce frame in 1972 and have used for many 100's of deuce frames since.
    pprather likes this.
  4. 3w Hank
    3w Hank
    Yes, I figured out 1.75” and 2” rear.
    -Just saw this.
    I really like the A-Ford brake bar, but its not mention on the diameter.
    If the one I bought has a nice curve I will use it.
    3/8 or 1/2” bolts ?
    Maybe lathe/mill a adapter that goes over bar instead of weld bar to plate ?
    ( se pic )
    Donut Dave likes this.
  5. pprather
    pprather
    @sloppy jalopies , do you have the diameter of the Model A brake bar for this rodder?
  6. 31Apickup
    31Apickup
    The Model A brake bar is slightly smaller diameter on one end. I can measure mine tomorrow.
  7. Phil Brown
    Phil Brown
    1 7/16" for most of the bar then necks down to 1" at the very ends
    Tman likes this.
  8. 3w Hank
    3w Hank
    I'll bought one here today ( funny how so much Ford parts I found very close to me !
    If I start from zero and lenghts of ca ; 23" one end ( to left on picture ) is 34 mm ( 1.34" ) and the other end is only 33 mm ( 1.3" ) but the issue is the right side cone into a less diameter.
    I could not see that problem in the movie I showed.
    ( maybe this brake shaft is different made/years ? )
    trey32 likes this.
  9. Best spreader bar ever, my 32 frame uses one
    I even started reproducing them a few years back
  10. 3w Hank
    3w Hank
    Yes, its a very nice spreader bar !
    One thing I need to solve is one end cone to a less diameter.
  11. 31Apickup
    31Apickup
    Here is my spreader bar, I made up end plates and tapped them for the bolts. One end diameter measures 1.33” the other is 1.397”. B1BBA1AF-2BF5-4068-A10F-E1C1052A4249.jpeg
    Atwater Mike likes this.
  12. Atwater Mike
    Atwater Mike
    I always knew there would be a place for this tube, only disavowed it because of the diameter difference.
    Some things don't mind...:eek::D
  13. 3w Hank
    3w Hank
    Part of cool ’maybe’ but asymmetical diameter is not prefered.
    As I has 2 of them I might can cut it off, and use the end part so diameter will be equal.
    This spreader is so cool.
  14. 3w Hank
    3w Hank
    I bought one A-Ford brake shaft in US and found one in Sweden.
    Ide is maybe cut it so I has one equal diameter both ends.
    Don't know if I will use the bar for a licenceplate, maybe not but I got 2 out Ok.
  15. ronzmtrwrx
    ronzmtrwrx
    Nice. I’m enjoying watching your build as you figure out ways to get it done.
  16. 3w Hank
    3w Hank
    Thanks and I’m Very greatful for all help here at HAMB.
  17. deathrowdave
    deathrowdave
    from NKy
    Look at OT F450 draglink , best I remember they and be used very easily with a nice nice curve
