32 frame guys ~~~~~ some help please
Discussion in 'The Hokey Ass Message Board' started by 296 V8, Apr 19, 2013.
  1. 296 V8
    296 V8
    from Nor~Cal
    Do I have these holes IDed correctly? And can you confirm holes 1 - 5
    Im going to use the dimensions below to put this together so I need to know I have the holes right
    My plan is to go from a center line to the body holes to get the rails the correct distance from each other
    <DIR><DIR>1932 FORD FRAME RAILS ARE 12' 6" LONG.
    1932 FORD FRAME RAILS ARE 6" TALL THROUGH THE BODY AREA.
    1932 FORD FRAME RAILS ARE 2" WIDE FROM FRONT XMEMBER TO REAR XMEMBER.
    1932 FORD FRAME RAILS ARE 4" TALL AT THE REAR AXLE CENTER LINE.
    1932 FORD FRAME RAILS ARE 2 5/8" TALL AT THE FRONT AXLE CENTER LINE.
    1932 FORD FRAMES SHOULD BE 23 3/4" WIDE AT THE FRONT.
    1932 FORD FRAMES SHOULD BE 40" WIDE AT THE REAR.
    1932 FORD FRAMES SHOULD BE 25 5/8" WIDE AT THE FRONT AXLE CENTERLINE.
    1932 FORD FRAMES SHOULD BE 40 3/4" WIDE AT THE REAR AXLE CENTERLINE.
    1932 FORD FRAMES SHOULD BE THE SAME WIDTH AT BOTH THE TOP AND BOTTOM OF FRAME RAIL.
    1932 FORD FRAMES SHOULD BE 40" AT THE REAR MOST BODY HOLE.
    1932 FORD FRAMES SHOULD BE 43" AT THE NEXT BODY HOLE FORWARD.
    1932 FORD FRAMES SHOULD BE 43 1/2" AT THE NEXT BODY HOLE FORWARD.
    1932 FORD FRAMES SHOULD BE 43 1/4" AT THE NEXT BODY HOLE FORWARD.
    1932 FORD FRAMES SHOULD BE 40 1/8" AT THE NEXT BODY HOLE FORWARD.
  2. tinmann
    tinmann
    I think it's Kiwi Connection that sells a really good large poster format ch***is diagram. Worth the price.
  3. 296 V8
    296 V8
    from Nor~Cal
    Id like to do it this weekend / not wait
    thanks
  4. saltracer219
    saltracer219
    Google Wescotts auto restyling, click on TECH it will take you to their frame dimension chart and will give you a pdf file of a 32 frame with all the dimensions. You can print it out and your all set. Hope this helps, G.....
  5. alchemy
    alchemy
    1 and 3 are for the firewall. 2 is for the cowl band. Pretty sure 4 and 5 are for the A pillar and the front end of the subframe.
  6. 296 V8
    296 V8
    from Nor~Cal
    Thanks
    Got it
    [​IMG][​IMG]
  7. CTaulbert
    CTaulbert
    from Detroit
  8. 296 V8
    296 V8
    from Nor~Cal
    For now
    I just wanted to space them apart correct dimensionally - square it diagonally so I could ****e the rears back on ………….. If that makes sense.
