Hot Rods '32 front fenders versus 33/34
Discussion in 'The Hokey Ass Message Board' started by 35fordcoupe, Apr 27, 2021.
  1. 35fordcoupe
    35fordcoupe
    from Virginia
    I have searched on the topic and still am having a hard time confirming this pair. I got three fenders. The left one in the first pic I know and the other two I need help with.
    I believe the left one in the first pic is 33/34 pickup. It has the bump and the mounting surface to the frame is curved (pic 2).
    The middle one is flat on the frame mounting surface (pic 3), but has a suspicious distortion where the 33/34 bump would be, but no cutting or welding (pic 4). The bump seems too flat to just be a 33/34 hammered on. Maybe it's a 32 someone just hammered over 33/34 rivets trying to fit it?
    The right one in the first pic has a cut out where the bump would be, but the frame mounting surface is flat although the picture doesn't show well (pic 5).
    What do I have?
    Edit: Having a hard time loading the pics so I can reference them well so disregard my picture numbers and just call out what you see.
    Thanks!
  2. Corn Fed
    Corn Fed
    The black pair are 32. The single is 33-34 truck. See the very front mounting hole? 32s are centered in the flange whereas 33-34 truck are offset to the outside.
  3. 35fordcoupe
    35fordcoupe
    from Virginia
    Nice. Thanks for the tip. That's what I was leaning toward, but I didn't know what was going on in the crossmember area.
    So I have two 32 pairs (one with a wheel well) to make something work on my pickup. Unfortunately the 33/34 truck fender is probably the nicest.
    Thanks
