'32 Heavy Axle vs Model A
Discussion in 'The Hokey Ass Message Board' started by ejay$, May 8, 2010.
  1. ejay$
    ejay$
    I tried a search but I'm looking for a pic of them next to each other. I know what both look like but I'm wondering how much of a drop it gives you over a stock Model A axle. Thanks guys.
  2. RETROD
    RETROD
  3. dudley32
    dudley32
    I used a regular 32 axle on my roadster with a reversed eye spring..
    by using 16 inch wheels...I got close to four inches...and still run mechanical
    brakes...thanks to Elrod...d32
  4. doctorZ
    doctorZ
    it won't give you drop unless it's a dropped axle. if you want to maintain mechanical brakes with a dropped axle, you'll also want to use 1932 perches. if using model A or 1932 perches with a new reversed eye spring you'll need specific shackles because the new springs are 3/4" eyelet and the stock perches are 11/16". you can always get a stock spring reversed as well. additionally, the 1932 heavy beam has a 2" perch boss while the model A is 2-1/4". this means that you'll either have to take a set of 1932 bones and shorten them to the correct length or make a bushing to make up the 1/4" difference between the heavy beam and the model A wishbones.
    hope that helps!
    -rob
  5. dudley32
    dudley32
    ^^^ditto^^ he's exactly right....but it will work... look at my 31 roadster
    and you don't have to use a new spring..just reverse the eye and you eliminate a step...
    d32
  6. 296 V8
    296 V8
    from Nor~Cal
    Stock 32 in place of stock 28 to 31 will lower it 1 1/2"
  7. Dennis Lacy
    Dennis Lacy
    Replacing a model a front axle with a '32 or the thinner-looking '33-'36 will lower the ride height approximately 1 inch all other components remaining the same.
    As was said, Model A axle is 1/4" thicker at the spring perces so will reqire a spacer of the same thickness to make up the difference when installing Model A wishbone on a '32-'36 axle.
  8. ^^^^^^^^^^^what he said.
  9. 296 V8
    296 V8
    from Nor~Cal
    Oh, I must have used the wifes tape :rolleyes:
  10. dudley32
    dudley32
    1 1/2 is correct..... if that is all you do...d32
  11. Dennis Lacy
    Dennis Lacy
    My bad. I have never actually compared the two for a precise measurement. My approximate 1" was based second hand info that was evidently incorrect.
  12. flthd31
    flthd31
    Here's a picture of them side by side.
  13. ejay$
    ejay$
    Cool guys. I appreciate the info that was exactly what I wanted to know.
  14. doctorZ
    doctorZ
    my mistake! i'm pretty sure the rest of my dimensions and such are correct. right?
