Projects 32 make over started
Discussion in 'The Hokey Ass Message Board' started by pantodd74, Jan 3, 2025.
  1. Moriarity
    Moriarity
    SUPER MODERATOR
    you have the video set to private
  2. Onemansjunk
    Onemansjunk
    from Modesto,CA
    Guide plate, 19Eddy30, called it.
  3. pantodd74
    pantodd74
    Sorry about that as I have only uploaded 2 other video's to YouTube. It should be good now.
    Moriarity likes this.
  4. breizh
    breizh
    from France
    Wouah j'adore :)
  5. pantodd74
    pantodd74
    So yesterday I got the head and tail lights working. The brake light switch is bad so that will be replaced. Also I think the driver side headlight needs a new unit as the low beam works only. I checked the siring and have continuity on all wires. Taking the driveshaft to get shortened and freshened up with the proper yoke and new u-joints. Then come home and finish some more of the to-do list.
  6. pantodd74
    pantodd74
    Dash is installed and floor done and sitting there for now. Still have a few things to do before I set the floor for good. Cost me $38 bucks to remake the floor. New 4x4 sheet of 3/4 plywood and a $14 6x8 area rug. 20260317_180307.jpg
  7. pantodd74
    pantodd74
    We got back from Aruba last night. What a great vacation! Picked up the driveshaft today and installed it. The floor is installed and shifter boot. Tomorrow the seat goes in and the steering shaft and wheel installed. Then get the rear wheels back on and grill. Turn it 45 degree's and move it out of the shop finally! Fire it up and see what happens.
  8. pantodd74
    pantodd74
    Got everything all finished up and took it for a spin around the block. Still need to get the transmission tuned with the software provided. I did learn that the main harness plug was 180* out. I had all kinds of error codes. Called US Shift and had to unplug and turn it 180* and plug it back in. All the codes disappeared. Set the TPS and took it for a spin. It's a whole different animal than what it used to be. Throttle is very snappy.
    SPEC and AHotRod like this.
  9. pantodd74
    pantodd74
    The finished product for now. Still gonna swap the ole rear suspension for new and I'm probably gonna swap the 57 rear end for a Ford 9 inch. But none of that is gonna happen till the winter. 20260328_105737.jpg 20260328_105800.jpg 20260328_105753.jpg 20260328_105745.jpg
  10. patsurf
    patsurf
    pantodd74 likes this.
  11. pantodd74
    pantodd74
    Alright fella's now that the hotrod is done. I wanna be able to stretch it's leg's with a bigger fuel tank. Right now it has a spun 9.7 gallon fuel cell behind the seat. I'm wanting to know what we can buy and install for more gallons? Also would like to get something with a gauge and is easier to fill than what we have. Any idea's?
  12. alchemy
    alchemy
  13. RockyMtnWay
    RockyMtnWay
    Are my eyes deceiving me?
    Hint hint….i like a little jam on my toast.
  14. pantodd74
    pantodd74
    The old valve cover gaskets leaked like a Harley. I have changed them out to the ol'e cork gaskets.
  15. alchemy
    alchemy
    He means that you need a jam nut on every rod end joint in your suspension and steering. It’s common sense.
  16. Corn Fed
    Corn Fed
    So have you given your wife a ride in it yet? What does she think of the headers?
  17. pantodd74
    pantodd74
    If it would ever stop raining she could take it for a spin. Some jamb nuts are on there. Was too early for me this morning.
  18. alchemy
    alchemy
    Your picture clearly shows no jamb nut on the heim end into the hairpin. Needs to be there or the looseness will eventually erode the threads and it will fail.
    panhead_pete and 19Eddy30 like this.
  19. pantodd74
    pantodd74
    Ahhh now I see what ya'll talking about.
  20. 29Sleeper
    29Sleeper
    from SoCal
    I'm late to the party. Consider the TH200-4R. It is a 4-speed overdrive that is the size of the TH350. It should be fine in stock form in a mid HP light car and can be built for more HP if needed.
  21. pantodd74
    pantodd74
    Your wayyyyyyy late to the party. Already running a new 4l60e.
  22. 29Sleeper
    29Sleeper
    from SoCal
    Figured I toss it out there anyway - in case someone else is doing a build.
  23. pantodd74
    pantodd74
    So finally had some time to finish tuning and making sure all was good. The wife finally took her hot rod for a drive today.
    SS327, 19Eddy30, RICH B and 2 others like this.
  24. glennpm
    glennpm
  25. breizh
    breizh
    from France
    Wouah
    un peu bruyant quand même
  26. pantodd74
    pantodd74
    Loud is proud! I had to copy and paste your response Frenchie! lol All is good and momma is happy and that is all that matter's to me! Motor on my gearhead friend's!
