Technical 32 rails…..original or repro’s
Discussion in 'The Hokey Ass Message Board' started by deucepickup32, Oct 30, 2023.
  1. The metallurgy question I asked was just because of comments suggesting the original was better. I thought maybe someone did a test.
    I’ve got a vintage pair of made in the USA Chuck Taylor shoes. There is a difference with the new overseas ones.
    A repop 32 grill shell doesn’t have all the details an original does.
    But both look good cruising down the road.
    oliver westlund likes this.
  2. Adriatic Machine
    Adriatic Machine
    I don’t have any worthwhile opinion but I will say this; the original style solid bucked river construction is second to none. I’ve done a LOT of riveting in my aviation days but that was mostly aluminum rivets. I would love the opportunity to buck those big steel rivets used to ***emble a ch***is.
  3. Early Ford frames were made to flex as part of the suspension. if you box them then the suspension has to do it all, I'd go unboxed like the original.
    deucepickup32 likes this.
  4. jersey greaser
    jersey greaser
    building real 32 Todor right now, only found the vin stamped in two spots on the left rail 1 near the firewall leg and 1 near the rear axle bend, lucky the vin and ***le both match
    ratamahata likes this.
  5. Nailhead A-V8
    Nailhead A-V8
    I know for a fact a lot of people have junked original frames partly out of the convenience of having a "bolt together" situation which brings up the "kit car" reference...it has been proven (on here) that a talented metalworker can build a '32 roadster out of sheetmetal or out of a Volkswagon after that the matter becomes purely subjective...I hate seeing old things discarded so to that end I bought a set of totally fubar originals (no one else on here would touch these w 10 ft. pole) because it's my bag ....or maybe I'm just a masochist:D I definitely don't think they will add any cache or value to the car...if anything probably detract;)
  6. DDDenny
    I've looked everywhere and can't find this thing you call VIN!
  7. jersey greaser
    jersey greaser
    guess we were lucky, the car sat on the factory rails ,
  8. dave agosti
    dave agosti
    Frame number was the original engine and transmission number. I believe the frame was stamped after the tested engine was installed. Model B carried on the Model A number starting at 5,000,000. V-8 started in March 1932 at 18- ETC.
  9. jersey greaser
    jersey greaser
    my understanding was ford did not vin stamp the engines as they knew those would wear out and be replaced, they did stamp the trans to the frame numbers.
  10. dave agosti
    dave agosti
    I don't think so. Can you verify?
  11. razoo lew
    razoo lew
    from Calgary
    My old, but not 1932 ford is stamped on the transmission, not the engine for what it is worth.
    jersey greaser likes this.
  12. alchemy
    alchemy
    Model A’s we’re the last Fords to have the block stamped for a long time.
    X38 likes this.
  13. A Boner
    A Boner
    It’s funny…an old Ford hot rod with 99% old original parts can be problematic if the frame is replaced, but if it has an original frame with the vin…99% of the parts can be replaced and no problemo, with the DOT!
  14. Ain’t that the truth
    seb fontana likes this.
  15. Interesting comment.
  16. NoSurf
    NoSurf
    Let me know when you want to come up to New Hampshire....
  17. 325w
    325w
    Why coupe has a TCI frame under it. I was in such a hurry to get the car together I didn’t finish out the grinder marks it came with. So if you see it it’s a repop frame. Got a quarter call someone who cares.
  18. HOTRODPRIMER
    HOTRODPRIMER
    If you plan on cutting it up why use the original rails, go repro. HRP
    325w likes this.
