32 rear wishbones
Discussion in 'The Hokey Ass Message Board' started by Equipped28, Dec 18, 2009.
  1. Equipped28
    Equipped28
    Hi
    has anybody got any pictures of and measurments of stock 32 rear wishbones as i have just bought a pair that are supposed to be stock 32 rears but as ive never seen a pair before they could well be model a ones
    thanks
    Harley
  2. There are two types - the V8 & four cylinder ones are slightly different. The back mounting 2 hole bracket is straight on the 4 cyl ones??? & the V8's are angled. Or it could be the other way around. I'll get some measurements later when I'm in the garage
  3. Bruce Lancaster
    Bruce Lancaster
    Model A bolt onto the brake flange bolts, so end is parallel with centerline of car and bolt holes are large.
    99% of '32's use the early rear, part that bolts to a little flange on axle housing angles in to parallel with driveshaft, bolts fairly small.
    '32's built in last month or so of production look the same but last bit goes straight with wishbone, angled to centerline. Completely different rear.
  4. Equipped28
    Equipped28
    heres some pics of my so they're 4 banger un's???
  5. Equipped28
    Equipped28
    so they're A ones then i honestly did'nt have a clue but they were cheap so cheers for the confirmation
