Projects 32 roadster - front wheel backspacing
Discussion in 'Traditional Hot Rods' started by Crotty 32, Jan 20, 2026.
  1. Crotty 32
    Crotty 32
    I am about to order my wheels and tires for my roadster project. I am pretty confident with my rear wheel dimension decisions, but I am not sure what backspacing to go with for the front wheels. An online search left me empty. Any recommendations?
    Rear
    Wheel mounting surface to WMS = 57”
    Tires = Diamond Back Auburn Deluxe 750R16
    Wheels = Wheel Smith vintage 16x6 with 3.75” backspacing (5 x 5.5 bolt pattern)
    Front
    WMS to WMS = 56”
    Tires = Diamond Back Auburn Deluxe 550R16
    Wheels = Wheels Smith Vintage 16x4.5 with ???? backspacing (maybe 2”?) (5x5.5 bolt pattern)
    Getting sick of looking at these plywood mockup wheels.
  2. 60 Special
    60 Special
    from Omaha Ne.
  3. HOTRODPRIMER
    HOTRODPRIMER
    Gary can probably help you, he has built more '32 Fords than most people.HRP
    lothiandon1940 likes this.
  4. hotrodA
    hotrodA
    Front brakes? How much do you want exposed?
    @krylon32 to the white courtesy phone please.
    Just Gary and lothiandon1940 like this.
  5. alchemy
    alchemy
    I think steelie style wheels look best with a neutral offset. Centered.
    Crotty 32 likes this.
  6. Moriarity
    Moriarity
    SUPER MODERATOR
    I think you need to consider the scrub radius and the fact that radial tires age out after 6 years. How long until the car is ready for the road?
    Nailhead Jason and twenty8 like this.
  7. Crotty 32
    Crotty 32
    I’m running the Lincoln front drums from Boling Brothers, so leaving a little exposed is good with me, but not all of the drum.
  8. Crotty 32
    Crotty 32
    Very good and safe thought. I am in year 5 of the build and it is nearly ready to be blown apart and painted/engine rebuilt. I am hopeful to get it on the road in 3 years, giving me some time/miles with these tires before replacement.
  9. Moriarity
    Moriarity
    SUPER MODERATOR
    so in three years your tire life will be half over with no miles on them....
    19Eddy30 likes this.
  10. RockyMtnWay
    RockyMtnWay
    This element often gets overlooked and I’ve seen some wonky offsets pushing the wheel out way too far.
    I’ve used a few sets of the auburn deluxe 550r16s and found 2.75” (on a 4.5” wide rim) to 3” (on a 5” wide rim) a decent fit with that height tire.
    Crotty 32, Moriarity and twenty8 like this.
  11. 19Eddy30
    19Eddy30
    from VA
    I use a 50/50 on front of A's & 32's
    3-1/2 4s
    The wides 5 , maybe one time 6
    All narrow tire tho,
    Back about 15 yrs ago I was complaining that the front tire's & rear
    Where $150-200 each I put around 30k on rears with black tracking many many times , rear still had 1/4 tread Bridgestone 406 -427 sbc
  12. krylon32
    krylon32
    from Nebraska
    4.5 or 5 inches wide I usually order them with a neutral back set if possible. Done a number of 32's this way.
    Crotty 32, Just Gary and HemiDeuce like this.
  13. Crotty 32
    Crotty 32
    Thank you all for the advice!
