Technical 32 roadster shifter
Discussion in 'Traditional Hot Rods' started by Nicholas minor, Mar 12, 2025.
  1. Nicholas minor
    Nicholas minor
    I'm in a search of a new shifter for my car has a th350 what is everyone running looking for input thanks in advance
  2. nochop
    nochop
    from norcal
    IMG_7522.jpeg Lokar in my coupe
    Nicholas minor likes this.
  3. DDDenny
    ydopen and Nicholas minor like this.
  4. krylon32
    krylon32
    from Nebraska
    I've turned into a column shifter guy, finally got tired of fighting the floor shift lever with my right leg. I've got a Lime Works column and shifter in my daily driver deuce pickup and love it. Also put a column shift in my 40 coupe. Also putting a column shifter in a new deuce roadster I'm currently working on.
  5. BJR
    BJR
    Whats the problem with what you have now?
    Just Gary likes this.
  6. Nicholas minor
    Nicholas minor
    For 1 my ankle rubs up against the housing that is in it also won't come out of park come to find out the way this ones is built has plastic components that are warn out
  7. I've been using a Genny Shifter for 26 years that works fine, although I don't know how the new ones compare quality-wise.....
    ydopen and Dirty Dingus Magee like this.
  8. 05snopro440
    05snopro440
    Same here. As a tall guy, every bit of floor space in this old stuff helps. I find a column shifter easily functional too.
    ydopen likes this.
  9. RodStRace
    RodStRace
    I've got a B&M ratchet shifter, which is kind of needed with the manual valve body. It's great at performing the job, but it's kind of short and in the way. I've experimented with a longer handle and that works better, but impacts being able to move around in the car. I'm considering moving it's location and fabricating a longer handle or going with a lokar style, but with the side action rather than the ****on. It probably won't do what I want (one gear at a time) so I'm still on the fence. I'd prefer the lack of a big branded lump on the floor, too.
    I would rather support Lokar, but they don't do a side shift.
    https://lokar.com/transmission-shifters-accessories
    This place is a Hoffman group (BAD NEWS) and it says US Designed, which means offshore stuff.
    https://www.americanshifter.com/catalog/shifters/gm-350-th-transmission-shifters
  10. vtx1800
    vtx1800
    When I built the 27 T roadster I didn't want a floor shifter, although it would have been easier. Maybe? I used an upper 1959 (or so) Pontiac column and mated it with a 58 Studebaker "lower end" because the Pontiac shifter lever took up so much space. I used the Studebaker shift lever and neutral switch and the Pontiac turn signal switch. IMG_5113.JPG IMG_5328.JPG
    Tim, Nicholas minor and Algoma56 like this.
  11. Nicholas minor
    Nicholas minor
    Ya this is the one currently in the car wich takes up a bunch of room and the cover that was made for it to sit on
  12. 05snopro440
    05snopro440
    Looks like a Ford piece if I remember correctly.
    19Eddy30 and Algoma56 like this.
  13. RodStRace
    RodStRace
    Yeah, Mid 70s ford look.
  14. RodStRace
    RodStRace
  15. Nicholas minor
    Nicholas minor
  16. pprather
    pprather
  17. nochop
    nochop
    from norcal
    18” from the hex nut to the top of shift knob
  18. spudshaft
    spudshaft
