Hot Rods 32 Roadster windshield question
Discussion in 'The Hokey Ass Message Board' started by moter, Mar 1, 2010.
  1. moter
    moter
    I will be installing the windhield frame on my car soon and have a question, does the gl*** just sit in the frame or is it glued in? Is there any "rubber" or material that goes between the gl*** and the frame?
    Thanks for the help
    Scott
  2. alchemy
    alchemy
    Ford used a rubber/cork/fabric tape stuff. I found it hard to use. I used the black urethane that all gl*** installers use nowadays, and it makes for a more watertight seal. Use a couple small strips of rubber innertube near the corners as you are installing to prevent the gl*** from touching the metal. Then fill the void with the urethane.
    You will use two thousand paper towels and a gallon of thinner cleaning up the edge (while it's still wet) and making it look nice, but it will be a clean joint that seals tight.
  3. krylon32
    krylon32
    from Nebraska
    I still use the fabric channel when installing gl*** in the roadster windshield. In the land of rocks and gravel where I live I have visions of destroying the frame if I had to replace the windshield and it was glued in. The fabric also lets the gl*** float in the frame as it does have some flex.
  4. moter
    moter
    yea..a concern of mine is a rock chip...lots of screwed up roads here in Austin. Where would you purchase the fabric channel?
    Thanks
  5. krylon32
    krylon32
    from Nebraska
    My gl*** shop has it in stock.
  6. alchemy
    alchemy
    My gl*** shop gave me the last dusty roll they had in stock. Said they don't use it any more.
    I can understand using the setting tape instead of urethane for ease of removal. And with a roadster, if you had a slight leak, it wouldn't be the only one.
