Need to find out for sure the stock location of steering box hole in 32 ch***is,going ti drill sector hole for 56 f100 box and found out its 35 11/16 from c/l of the back spreader bar hole to center of sector hole,want to make sure thats right and how far down from top of rail???Thanks
That seems like a loaded question. There are alot of variables to consider such as pedal placement and seating position for starters. I would be hesitant to just mount it without sorting some other things out first , but I'm a puss.
30 coupe,107 wbase,pinched,392 hemi,36 dash,i would not think seating or pedals should matter,just need the sector hole loc so i can put that hole in and move the steering column up or down(to figure the column drop) and side to side with the wheel mounted,the flange will be cut off,than i can tack new flange,the steering should go in first than the pedals in my opinion but thats why im asking,the swap has been done alot in the stock location with a 56 box,just want to be sure and if so i need the stock deminsions. thanks
