Hot Rods 32 tail light bulbs
Discussion in 'The Hokey Ass Message Board' started by louder50, Dec 6, 2020.
  1. louder50
    louder50
    from Michigan
    My 32 tail lights have #1141 bulbs in them. I want brighter bulbs but don't think I want led lights. 1156 will fit and are 400 lumen instead of 260 lumen. Has anybody done this? I'm worried about the heat inside the housing.
  2. mitch 36
    mitch 36
    I don't believe heat is going to an issue, I have 1156 bulbs for running lights and a halogen for the stop light inside my 36 Chevy housings without an issue for the last 41 years. Also ran the same setup in my 36 Ford tails which would be very close to your 32s. is there just one bulb ? ,,if that's the case you will need an 1157 that has dual filaments. It really helps if you paint the inside of the light housing GLOSS white, it really works to reflect the light .I hope this is of help,,, Mitch
    upspirate likes this.
  3. pprather
    pprather
    I too recommend gloss white on inside of taillight bucket. It's surprising how much it helps.
    1157 bulb heat will not damage anything.
    upspirate and stillrunners like this.
  4. alchemy
    alchemy
    I used a halogen install kit from Julianos in my 32 sedan. That made a MUCH brighter brake light. But it doesn't have a new Honda style LED look to it.
    And, painting the inside of the bucket white helped a lot too.
  5. 5window
    5window
  6. Mr48chev
    A second for the gloss white on the inside of the tail light bucket. That made a m***ive difference on my home fabricated tail lights on my 48 and on the stock 71 GMC lights on that truck.
    I was thinking that there was a brighter version of a 1156 just as there is a brighter non LED replacement for the 1157. I can't find what I was hunting in a quick search though.
  7. 5window
    5window
    I think this is the brighter replacement for the 1156: https://www.ronfrancis.com/prodinfo.asp?number=B-1015
  8. hotrodA
    hotrodA
    There is a brighter replacement for 1157 that is/was used on semi-trailers.
    I used them on my HotrodA roadster, but it’s gone down the road.
    I’ll check my stash and see if I can find the #.
    They were very bright in the 39 housings painted white inside.
