Technical '32 transmission mount
Discussion in 'Traditional Hot Rods' started by hotcoupe, Apr 6, 2024.
  1. hotcoupe
    hotcoupe
    Hello, is anyone still providing the service to re- vulcanize the '32 transmission mount.
    Thanx,
    Tom
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
  3. continentaljohn
    continentaljohn
    Tom I haven’t seen anyone doing it anymore and been buying the reproduction ones.
  4. hotcoupe
    hotcoupe
    Johnny Gee, I want to have my original trans mounts re- vulcanized, the mounting holes in the re- pops are drilled/punched incorrectly.
    Continentaljohn, thanx for the response.
    I thought I remember a shop out in California was doing that work at one time.
    Tom
  5. continentaljohn
    continentaljohn
    Tom is that a new repop that was drilled wrong ? I’m curious as I have a couple of old ones and they fit nicely. image.jpg
  6. hotcoupe
    hotcoupe
    Continentaljohn, you're lucky, some of the re- pops are punched correctly and some of them aren't. I have two that have been punched incorrectly. I' m not able to take an image of them right now, but if I remember correctly two holes don't line up. This topic was discussed a short while ago on the HAMB. Do you remember which vendor that you purchased yours from?
    Tom
    Kiwi 4d likes this.
  7. Kiwi 4d
    Kiwi 4d
    @continentaljohn , a heads up on where not to purchase or who makes nice ones . We need one soon. Thanks
  8. I think All ford parts in Campbell CA revulcanize them.
    Al.
  9. clem
    clem
    I got one in 2017 from AJays here.
    Bolted straight in as I recall.
    Don’t know if he still stocks them.
  10. hotcoupe
    hotcoupe
    Big Al, thanx for the lead. I will call "All Ford Parts" Mon. A.M.
    Tom
    Big Al likes this.
  11. continentaljohn
    continentaljohn
    I bought them awhile back but don’t use alot of aftermarket parts and when I do I would use **** Spadaro, joblot and the place in Minnesota. Unfortunately don’t believe any of them are open any longer.
    I did check the others I have and none of them have names stamped on them . It shocks me that they can’t locate the holes correctly image.jpg
  12. alchemy
    alchemy
    How far off are these holes? Can’t you just do a little filey-filey and away you go? The mounting bolts should hold it tight.
    clem likes this.
  13. hotcoupe
    hotcoupe
    Alchemy, yes I could re- work the part and make it fit, but I like to use original parts if I can, or re-pop parts that don't require m***aging. This is going to be my last car project, and I want it to look like the image in my minds eye. If you know what I mean.
    Tom
  14. NealinCA
    NealinCA
    I have purchased several re-vulcanized originals from All Ford Parts in Campbell. They have required a good core in the past.
  15. hotcoupe
    hotcoupe
    Thanx to all that responded, as Neal stated above, All Ford Parts in Campbell CA. sells original '32 Ford transmission mounts that have been re- vulcanized. For anyone that is interested, they currently charge $50.00 plus an original core.
    Tom
    V8-m, Big Al and Hitchhiker like this.
  16. Hitchhiker
    Hitchhiker
    Cheaper than the reproduction too!
