Hot Rods 32 trunk lid will not stay latched
Discussion in 'The Hokey Ass Message Board' started by 325w, Jun 9, 2025.
  1. 325w
    325w
    Have a 5 window. It’s built from several cars. Most all the handles a such are real. So I added a real trunk handle and latch. Cannot keep from working open. Other latch was repop and I hacked on it till it finally worked. Don’t want to hack this real one. Ideas?
    Thanks
  2. alchemy
    alchemy
    Original mounting opening for the latch? Original mounting holes for the catch? Maybe your pieces are not aligned so the latch isn’t fully closing. Maybe scoot the bottom catch over one way or the other.
  3. 325w
    325w
    I’ll try a hammer
  4. xix32
    xix32
    Does your latch housing have that piece of spring steel that the latch bar has to compress as it passes
    over it to get to the closed position ? Maybe that piece is weak and flattened out or missing.
  5. Deuce Lover
    Deuce Lover
    Trying to understand your latch issue.The 5W coupe latch has a swing out hook that when the handle is turned it grabs the bar that is attached to the body or a slot in the piece for a rumble seat car. It is not a spring loaded striker. Post a pic .
    micksmith and 19Eddy30 like this.
  6. swifty
    swifty
    UPAC 32-5 window body which supposedly replicates the Henry Ford stuff. Bob Drake latch and striker plate. The striker plate needed to be "tickled" and have a 1/4" packer under its mounting area for the whole assembly to work correctly. I know, repro body and repro parts but we never got 32-5 windows here in Australia.
