Hot Rods 32 Tudor door question
Discussion in 'The Hokey Ass Message Board' started by PursuingPerfectPaint, Aug 10, 2017.
  1. I recently purchased a original 32 Tudor door and have decided not to use it on my project. The door needs a small patch on the inner door frame and the outer skin was poorly patched some time ago ( bottom 6")
    Would I better to sell it as is or should I invest the time to strip it do the metal work and epoxy prime it so it's all solid for the next owner.
    Thanks in advance for your opinions and advice.
  2. big duece
    big duece
    from kansas
    I would sell it the way it is. Some guys just like to do their "own" work. Otherwise it might get looked at that your covering up a bad patch. Buyer can see it for what it is.
  3. deucetruck
    deucetruck
    from Missouri
    Sounds like good advise to me. Driver or p***enger side?
    PursuingPerfectPaint likes this.
  4. Corn Fed
    Corn Fed
    Leave it as is. I would much rather patch my own than buy one already done. That way I can make it fit my body if adjustments are needed.
  5. P***engers side
  6. Thanks for the help guys I appreciate it.
  7. Pewsplace
    Pewsplace
