Hot Rods 32 Tudor Father/Son Build
Discussion in 'The Hokey Ass Message Board' started by gearhead64ac, Dec 28, 2012.
  1. gearhead64ac
    gearhead64ac
    Not planning on running a PCV. Will just breath it through the intake
  2. cvstl
    cvstl
    from StL MO
    Not telling you what to do, but before you go much farther with that plan, I would do a little research. That engine is designed for it - and not just that one, but all engines need some type of venting of the crankcase. If you don't account for it, it will vent itself somewhere, likely blowing oil all over your nice shiny stuff.
    The ventilation burns off the condensation and keeps your oil from turning to sludge and being fouled with water.
    Search PCV with the Technical prefix and there is some really good info. Here is a small sampling of the discussions :
    http://www.jalopyjournal.com/forum/showthread.php?t=525612
    http://www.jalopyjournal.com/forum/showthread.php?t=616511&highlight=pcv
    http://www.jalopyjournal.com/forum/showthread.php?t=627132&highlight=pcv
    BTW, the reason that I asked is because I have the same type of setup and I don't want to cut holes in my valve covers. In the end, though, I think I'll add some moon style breathers to top side of my valve covers and attached the pcv to a Corvette style, sealed-cap filler tube.
    __________________
  3. timwhit
    timwhit
    A lesson learned by a friend was that ventilation, just in the wrong location, consumed oil...through the engine. Research it as suggested.
  4. 62131
    62131
    from glasgow,ky
    Hey great looking car. I would be interested in your wheels if you decide to up grade yours.
  5. rd4pin
    rd4pin
    from louisiana
    Super father & son project, that's what America needs now more than ever.
    keep it up, it's looking good.
  6. HotRodHighley
    HotRodHighley
    from cincy, oh
    Very nice looking sedan. Love the color.
  7. Henry VIII
    Henry VIII
    from Tulsa OK
    Hope you're planning to run fenders.
    Looks like a very nice straight body.
    Should be a good driver too.
  8. 40Standard
    40Standard
    from Indy
    nice rebuild. keep us posted on your progress
  9. Detonator
    Detonator
    from santa cruz
    Hmmm... this may be a clue to a problem we're trying to solve on a Naihead. When you say "through the engine" can you elaborate? Thanks.
  10. Dave Rondou
    Dave Rondou
    Nice looking sedan. Keep us posted.
  11. HOTRODPRIMER
    HOTRODPRIMER
    Love the dash insert and yeah the Halibrand's would look right the sedan HRP
  12. 1950-mercury
    1950-mercury
    I like it!!! Keep up the good work!!!
  13. dirt t
    dirt t
    I'm not a 32 guy but the front suspension looks too far forward?
  14. 383deuce
    383deuce
    I like it.....
  15. racemad55
    racemad55
    Speaking about the front suspension- no comments on I.F.S.? nice car by the way.
  16. Malcolm
    Malcolm
    from Nebraska
    The transformation is coming along nicely. I really like your color choice, also.
    Regarding the coilovers and leaf spring combo out back, it makes me wonder if the leaf springs are a bit weak and the coilovers were added by the previous owner to bring the back of the car up?
    Also, I tend to agree with the others - those 5-spokes that were on it look good!
    If you must change, Team III offers some great choices-
    http://www.team3wheels.com/
    Malcolm
  17. gearhead64ac
    gearhead64ac
    Appreciate the input. After doing some research I prob will do the PCV. I was thinking about drilling one on the back side by the firewall if I have the room. If not i will do the mooneyes like you. They have to come off for another coat of paint before final install. I will cut them then. Thanks again!
  18. gearhead64ac
    gearhead64ac
    I may run the americans for a bit this summer before we go to the halibrands. Once they are up for sale you will have a PM your way.
  19. gearhead64ac
    gearhead64ac
    We drove the car for about 1000 miles before pulling it apart and it rode very good. Obviously would love a nice dropped axle, but the welds and all suspensions parts were in such good shape it just made sense to keep it.
  20. gearhead64ac
    gearhead64ac
    Appreciate all the wheel input as well. 5 spokes will be on it while we save for interior and the final set of wheels.
  21. bscottstudio
    bscottstudio
    from Kansas
    If it is okay, I have 80,000 miles of experience in a 1932 tudor with the Posies parallel leaf setup. I had alot of body roll, at highway speeds, and gas shocks do help, but the ultimate fix is a sway bar, the coil overs probably will help. But the back of the car is high compared to the narrow width of spring location and highway winds cause body sway. This is just info to consider, so just get it on the road and drive it .
    Love the COLOR! Happy motorin, B-Scott
  22. gearhead64ac
    gearhead64ac
    A couple of build updates.
    Got the radiator mounted and will start hose and AC line mock up soon. Got the carbs mounted for good and linkage set up. Also started to figure out the fuel system. Was planning on running a manual pump but it started to get real busy real fast since we are running AC. So we ended up going with an electric pump. Got the tank set up with the sending unit and pick up as well. Also got a few update shots from the shop doing the woodgraining. Should be getting the dash and steering wheel back this weekend, then we can really start to crank on the dash and wiring.
  23. Generally accepted on a full-fendered ride...
  24. motoandy
    motoandy
    from MB, SC
    That is like hotrod ****. Love the color combo. Nice build. Wood graining is coming out great.Great for both of you. What color interior? Caramel Brown????
  25. 1badbaker
    1badbaker
    Thats one heck of a nice looking car. That color looks great on it.
  26. gearhead64ac
    gearhead64ac
    Appreciate the comments. You nailed it on the interior color. We want to do a brown that picks up the base coat of the woodgrain.
  27. gearhead64ac
    gearhead64ac
    Also forgot to mention we got the two back piece of gl*** installed.
  28. nailhead terry
    nailhead terry
    Like the wood grain and the color !
  29. socaljoe
    socaljoe
    Very good job cleaning up the past sins of this car. Great color choice too.
  30. KustomCars
    KustomCars
    from Minnesota
