'32 Vicky Progress == Chassis question
Discussion in 'The Hokey Ass Message Board' started by The37Kid, Jun 2, 2006.
  1. The37Kid
    The37Kid
    Took the floorpan off the Vicky ch***is a little while ago, and will have part of a cowl here within a week. I'm making progress. First step is to get a ch***is setup so I can rebuild the body. I may change my mind once the body is in primer, but right now I'm thinking about running the AMBLER head on a builtup B block. Model A front crossmember, '32 K member and a flattened '35-40 rear crossmember with a '40 spring with a '36 Ford rear. Dropped I beam front axle and uncut '32 wishbone. ASC rails or the Dearborn Rails with the stamped C notch in the rear are my choises. What can you tell me about aftermarket rails?
  2. HotRodDrummer
    HotRodDrummer
    The dearborn rails which are now Accu-rail, or did thier name change again? are the best aftermarket rail aval. not much work needed on the flanges to get them straight...I like them....They have mostly the proper shape especially in the reveal area.ASC rails are flat through there
    This frame has those rails.
    Hope this helps
  3. The37Kid
    The37Kid
    YES! That helps a lot, that ch***is sits the way I'd like mine to sit. Thanks for the correct spelling and history on the Accu-Rail rails. A local shop said the same thing about them and has a jig set to produce a good square base for this project. What have you got for a rear corssmember?:)
  4. HotRodDrummer
    HotRodDrummer
    would one of these do?:D
    The picture isn't that great, but it is a flattened 35-40 with holes
  5. The37Kid
    The37Kid
    That's it! I remember that ch***is from an earlier posting, very racy with the lightening holes, reminds me of a T-59 Bugatti.
  6. hotrodA
    hotrodA
    AMBLER head on a builtup B block. Model A front crossmember, '32 K member and a flattened '35-40 rear crossmember with a '40 spring with a '36 Ford rear. Dropped I beam front axle and uncut '32 wishbone. ASC rails or the Dearborn Rails with the stamped C notch in the rear[/QUOTE]
    Sounds like the PERFECT combo :cool:
    Keep the pictures coming.
  7. 3wLarry
    3wLarry
    from Owasso, Ok
    ...show-off...:p wish I woulda thought of it...:rolleyes: that's really nice.
  8. The37Kid
    The37Kid
    Keep the pictures coming.[/quote]
    I wish I could draw, there are featured in the Bentley Blue Train Special I plan to borrow.[​IMG]
  9. Kustm52
    Kustm52
    Any more pics of this frame???
    Brian
  10. The37Kid
    The37Kid
    I was doing a search in the Tech section on for info on flattening the 35-40 rear crossmember, and found the B*** coupe ch***is that has a lot of nice features like HotRodDrummer's. I really like the look of both of them.
