Technical 32 Window Glass
Discussion in 'Traditional Hot Rods' started by 32 Dave, Jan 25, 2022.
  1. 32 Dave
    32 Dave
    Does anyone out there have the factory dimensions for a 32 Ford Tudor driver side door window.
  2. alchemy
    alchemy
    You would need a template. There are basically only two straight edges on the thing, and there's no easy way to describe the angles/arcs on the front and top.
  3. 32 Dave
    32 Dave
    That’s what I’ve found. I’m making my second template but thought I’d see if someone knew the factory dimensions. The width across the top and also the bottom would be helpful. It’s the front edge that is the problem and that’s the arc/angle you mention
  4. pprather
    pprather
    When my slant window A Victoria needed a new door gl*** I just drove the rod to the gl*** shop in my town. Picked it up the following day. Easy.
  5. hotrodA
    hotrodA
    @alchemy x 2!!
    I can trace around a new door gl*** I had cut for my sedan if you want.
    PM your address.
    To save you the hell and expense I ran into doing mine:
    Make a template from my paper pattern to start.
    Install the front and rear runners/guides and felts.
    Slid the template in and sand to fit, and slide fully top to bottom. Mark R & L.
    Cut the new gl*** from the template.
    Mine were individually different R to L. Difference in the factory welded guides.
    One side would bind half way up. Sanded down one edge 1/16” and bingo.
    Algoma56 and 19Eddy30 like this.
  6. 32 Dave
    32 Dave
    Thanks for the offer. I made a second template out of Masonite and it fits nicely. I’ll have a local auto gl*** shop cut the gl*** for me. You are right about differences in the right and left doors. Nothing in these old cars are “standard”.
