Technical 324 Oldsmobile rebuild
Discussion in 'Traditional Hot Rods' started by Martin_F, Mar 17, 2012.
  1. 57 HEAP
    57 HEAP
    That engine sounds great Martin! Glad to see it running wit the new fuel pump.
    I saw a pro built engine test stand this past weekend. Fully adjustable with gauges and throttle control, $2500. Pricey, but gave me some ideas.
  2. blondie66
    blondie66
    I have a '56 olds 98 with that same 324. Have a few issues with it.. but sure is nice to see all the work you've done payed off. Mine runs.. but needs some tweeting.. I'm brand new, so I am slowly learning.. nice job!!
  3. Martin_F
    Martin_F
    Thanks blondie!
    Let me know if there is anything I might be able to help you with.
    Either way, you'll find a lot of nice people and great knowledge on here!
    Welcome
  4. HunterSpeed
    HunterSpeed
    from Austin, TX
    Great thread Fuxl. Congratulations, the rebuild turned out great. Lots of good information here so thanks for taking the time to do***ent your progress along the way. Just starting a rebuild of my 303 and this provided some needed inspiration!
  5. UNSHINED 2
    UNSHINED 2
    Took half the morning to read all the way thru this thread, but it was like a good book...couldn't put it down! Love these build threads, thanks for posting it! Looks great and sounds great too. One question, when you painted it, what kind of paint did you use? Did you just go in and ask the local paint shop for choices on high temp paint?
    Thanks.
  6. Martin_F
    Martin_F
    Sorry for the late reply.
    Thanks for the nice words.
    Lets see some pics!
    I just went into the local automotive paint store, and got regular paint that you'd use for your car too.
    Etch primer, base coat and clear. That's it.
    We'll see how long it lasts. It's already got some burn marks around the exhaust ports, but that's normal, I guess.
  7. landlubber
    landlubber
    from Virginia
    As I recall, the back of the 55 crank would need a relief cut for the jetaway torus. Sludge was caused by a cheapskate previous owner. I got a 51 Olds in same condition. Clean up and polish that Edmunds intake, it works nice. I'm using one on a 338" Olds w/later model 2GC carbs, for which I have a spare pair of adaptors. Also, you can get yourself a later 57-64 Distributor, just swap gear and use external adj. points. Chevy hydraulic lifters fit, and some guy makes an oil filter conversion using later spin filters. Deepen the oil return grooves and polish them on the heads, too much oil stays up top. Also might want to shim the pump spring (incr. pressure) to get more oil up to rockers as that's a weak spot in Olds oiling. Let me know if you want to sell the 55 hydro & flywheel.
  8. Bubbashead
    Bubbashead
    Wow! What a great thread. Thank you for taking the time to do***ent it all. I love these old Oldsmobile engines. I am rebuilding a '56 Olds engine. The car set in my bone yard for about a dozen years. I advertised it on CL for $650 ( whole car) and got no interest. So I decided to keep it and do a '31 model A. After seeing your engine,s condition when you first opened it up I realized how lucky I am. My engine came out of a 4 door hdtp with a 2bbl carburator. Before I pulled it I put in a battery and a little fresh gas and it started right up! When I took it apart it was clean, with no sludge at all. I suspect it had an amateur rebuild in the relatively recent past. There was a ton of silicon stuff everywhere. The bore was standard with about .002 taper. The crank is .010 undersize. I have a Wieand 2 four intake for it. Unless someone a can tell me why not I will keep the Jetaway trans since it looks to be in good shape.
    Thanks again for all the effort to do***ent your build. I really enjoyed it.
    Lanny
  9. Martin_F
    Martin_F
    Thanks for the kind words, Lanny!
    I also got a '56 Olds, and I plan on keeping the Jetaway. It's just a nice cruiser, so I don't think I'll ever hurt it. I do plan on getting it rebuilt though.
    Dual quad Weiand sounds like fun ;)
  10. RAT "T"
    RAT "T"
  11. CGkidd
    CGkidd
  12. Johnnyolds98
    Johnnyolds98
    Looks real good!
    Here's mine.[​IMG]
  13. CGkidd
    CGkidd
    Here is my 56 rocket engine. Sitting in my frame for my 50 stude. NCM_0039 (2).jpg hot rod engine.jpg
    550Coupe and jakespeed63 like this.
  14. Martin_F
    Martin_F
    Well, it's been some time now...
    Unfortunately we had a couple hick-ups along the way, so part of this rebuild had to be redone.
    I won't bore you with the details!
    Anyways, I got the engine back in the car now and just need to sort out a few minor things. Hopefully.
    Big thanks again to my buddy Tony @GOATROPER02 for the continued support.
    Now it's time to put some miles on this thing again!!!
    Here are some pics of the re-install:
  15. Arkas
    Arkas
    from Germany
    Damn Martin, great thread and what a *****in' engine. All blackened Olds with a golden heart. Awesome work you did there.
  16. GOATROPER02
    GOATROPER02
    from OHIO
    Looks right at home in there...........
    Bowtie Coupe likes this.
  17. seatex
    seatex
    Damn! I don't know how I missed this one! I just picked up a 330 with the forged steel crank this weekend from brother HAMBer ChopRod inc. what an inspiration! 'scribed!
  18. von Dyck
    von Dyck
    Those Ketterings look right at home in anything you put 'em in, Tony!
    BTW, I like your Coupe.
  19. Olds Dad
    Olds Dad
    my pants are tight...
  20. vtwhead
    vtwhead
    very nice project Martin! Now go drive that bad boy.
  21. Paul
    Paul
    Editor
  22. Heath.H
    Heath.H
    I also got my engine stand finished welding.
    The plan is to use it for cam break in. It'll have gauges, radiator, battery and all the other stuff mounted to it.[/QUOTE]
    Martin,
    Would you mind sharing the dimensions of the engine stand? Looks like it worked great!!
    jakespeed63 likes this.
  23. Martin_F
    Martin_F
    @Heath.H Thanks for the interest! I'm out of town right now, but I'll get you some dimensions when I'm back home...
  24. klilek
    klilek
    Great info, thanks everyone
