Hot Rods 325 dodge poly
Discussion in 'The Hokey Ass Message Board' started by kply39, Jun 9, 2014.
  1. kply39
    kply39
    from N.W. IL
    So whats the going rate for these 325 poly engines? Its out of a 57 dodge. complete with a push ****on 727 trans. The guy said it was ran last in 2001 and is sure if gas and a battery were hooked to it it would fire up. Thanks, Eric
  2. 73RR
    73RR
    ...it sounds like the one I recently picked up at an auction for $100...
    But every engine has its own value based on who is selling and who is buying. No, I would not sell mine for less than $500 as-is on the pallet.
  3. big M
    big M
    The value will all depend if you find someone needing one. If someone is restoring a '57Dodge ragtop and needs an original engine and cast iron torqueflite, could be worth as much as $1500 if it runs well. Parts for these are expensive, which would make a used, running engine/trans combo more desirable. Finding someone that is looking for one will be the hard part, however.
  4. sunbeam
    sunbeam
    Are you sure it's a 727 trans?
  5. hotrod.heaven
    hotrod.heaven
    the early polys have actually become very popular, but to a limited crowd, don't let anyone b.s. you. the trans is not a torqueflite if it is cast iron.
  6. daliant
    daliant
    From 56-61 the first generation torqueflite was cast iron. The 727 was the 62 and up aluminum case torqueflite
  7. kply39
    kply39
    from N.W. IL
    whoops I did mean to put torqueflite not 727. Guess I need to find me one of those limited crowd people!
  8. sunbeam
    sunbeam
    They were a good motor but if you want the look there are a lot of hemi heads out there to swap.
  9. swifty
    swifty
    Why bother, everyone can recognise a Hemi but not too many will be able to pick an early Poly. Some will even think it's a W motor.
