Technical 327 Chevrolet timing...
Discussion in 'The Hokey Ass Message Board' started by SDS, May 21, 2024.
  1. SDS
    SDS
    I put the blue springs in the dist. That didn't seem to make much of a noticeable difference, if any.
  2. 19Eddy30
    19Eddy30
    from VA
    I went back to post #118
    To present , So are you trying to Slow down the Speed of the Advancement?
    Or ??
    If so you can mix match springs ,
  3. SDS
    SDS
    The distributor comes with the stiffest springs available and a blue bushing. The MSD spring chart says that using 2 light blue springs with the blue bushing gives you all in centrifugal timing at 2800 RPM.
  4. 19Eddy30
    19Eddy30
    from VA
    @SDS
    Where you just making a statement that you did Not Feel a different's with
    The 2 light springs & blue bushing ?
    Or you have a goal that not on Paper.
    If you want to get more Precise and Tailored,
    You will have to make some of your Own bushing's . I have made my own optional bushings then MSD offers .(deg's)
    Some of the Older Mallory where simpler for adjusting to Taylor.
    More of selection of spring's.
    Then drill to remove wight
    or
    Add weight to weight's ...
    With a "Very" sensitive scale
    & Distributor Machine ,
    You could make your own distributor machine with thought with electric motor with variable speed control ,
    Timing Light .
    When it comes to checking springs
    A tool to test resistance / tension,
    I have No clue what that looks like ,
    I guess I am curious on the spring tester Now , I will look around to see how spring's are tested & measured that small o_O
  5. pprather
    pprather
    All in by 2800 sounds good for street use.
    SDS likes this.
  6. hepme
    hepme
    10 zillion opinions so i'll add mine. Had essentially the same thing, used med. springs, about 35 degrees total all in. Be sure you KNOW absolute 0 degrees, look it up on how to find it. **** performance and starting--junk it.
  7. SDS
    SDS
    Originally used a piston stop to find TDC, did it twice. Last week, used a dial indicator to confirm TDC and it was dead nuts on the mark from the piston stop exercise. Is that what you mean by absolute zero degrees?
    The original MSD springs are like garage door springs, there's no way I was getting any mechanical advance at idle
  8. SDS
    SDS
    What are your thoughts on what plugs I should be using and what gap ?
  9. 19Eddy30
    19Eddy30
    from VA
    Flat top piston
    Ac 45 ts
    Autolight 25 or 26
    Cross to what ever brand
    I like NGK & a shinny plug
    Gap 30-40
