Technical 327 dying in gear
Discussion in 'The Hokey Ass Message Board' started by Ken Sharp, Apr 9, 2024.
  1. Ken Sharp
    Ken Sharp
    Hey y'all, Im at my wits end..... I have a 67' 327, converted pcv system to the valve covers, swapped out intake to a Edelbrock 2701 performer intake and a Edelbrock 600cfm carb. Starts and idles just fine, goose her and she revvs right up. Put it in gear and rpms drop and she dies. I can feather the gas to keep her running while stepping on the brake. Keep her at @900 rpm acts like she is supposed to.... Come off of the gas she will die. Timing is on, checked for vacuum leaks and none to be found, Carb is brand new. ..... Does have the draft tube in the rear of the block and I have that plugged.
    Am I missing something obvious?... This Bi&$% is driving me nuts... Take her out driving and she runs like a striped ape....
    Thanks for any input y'all can give me..
  2. Dan Hay
    Dan Hay
    Turn the idle screw in a little on the linkage. Not enough rpm, maybe your converter is too tight. Then set the idle mixture screws per the instructions.
    SS327 likes this.
  3. Oneball
    Oneball
    Is it a manual or auto?
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Do you have a breather cap any where? “Timing set” to what?
    guthriesmith likes this.
  5. Ken Sharp
    Ken Sharp
    I set the idle @950 rpm and air/fuel are set accordingly.
  6. Ken Sharp
    Ken Sharp
    2 speed powerglide
  7. Ken Sharp
    Ken Sharp
    Yes sir... Have a push pvc on the p***enger valve cover, vented breather/oil fill cap on the drivers side.... I set the timing to initial of 12 degrees
  8. Oneball
    Oneball
    As you’ve changed the intake I’d be looking for a vacuum leak, ie intake not sealing properly to heads or carb.
    69fury likes this.
  9. Ken Sharp
    Ken Sharp
    Thats exactly what I was thinking but i hit everything with carb cleaner and no leaks were found
  10. Doublepumper
    Doublepumper
    from OR-WA, USA
    Vacuum advance, have one, is it working after the swap?
  11. Ken Sharp
    Ken Sharp
    Yep vacuum advance is working... of course disconnected when setting timing
  12. Oneball
    Oneball
    Maybe the leak is via the lifter valley????
    Have you tried richening the mixture and seeing if it does anything? Is the carb new?
    winduptoy likes this.
  13. Dan Hay
    Dan Hay
    Well, if it won't run at 950 you need to set it higher until you figure out if you have a vacuum leak or something.
    SS327 and Tim like this.
  14. jaracer
    jaracer
    Look down the carburetor at idle. Is there fuel dripping out of the venturii's? There shouldn't be. If there is, you are trying to idle on the main metering system rather than the idle system. That means that the idle system is either too lean or the system isn't working (plugged up).
    I had an Edelbrock carb that ran on my truck for 8 or 9 years and worked perfectly. One day I was coming into a parking lot and it died when I let off the throttle. Something in the fuel system found its way into the carb idle circuit. It ran perfectly as long as you didn't try to idle. I went through the carb and could only get it to idle on half the idle circuit. The carb cleaner now days isn't like the old dip basket cleaners we used to have. A buddy who had just switched his hot rod to fuel injection offered me his Edelbrock for $100.00 and I jumped at the chance.
    Cooon and winduptoy like this.
  15. Ken Sharp
    Ken Sharp
    Yes sir.. brand new Edelbrock
  16. Oneball
    Oneball
    Have you tried disconnecting the pipe to the pcv and plugging it.
  17. Ken Sharp
    Ken Sharp
    The hose coming from the front of the carb to the pcv?.. I have not... I will try that tonight
  18. Have you tried attaching a vacuum gauge ?
    They will tell a lot about an engine .
    Tommy
    winduptoy and bobss396 like this.
  19. Oneball
    Oneball
    Yep. If pcv is working properly plugging it will give you a very slight change in idle. But if something is wrong with the pcv it’ll make a very noticeable change.
  20. jimmy six
    jimmy six
    I check for vacuum leaks with starter fluid spray wit a stinger nozzle. I’ve found them in strange places on intakes edges.
  21. bobscogin
    bobscogin
    Have you put a gauge on it? What's the vacuum falling to when it dies?
    Desoto291Hemi likes this.
  22. Illustrious Hector
    Illustrious Hector
    Is gas dribbling in the venturis at idle? Just cause it's new means nothing Edelbrocks are finicky about float levels. Sounds like that, or vac leak.
  23. Ken Sharp
    Ken Sharp
    Yes sir... it's a little difficult to get a good reading.. I am running a Comp Cams Thumper... that gives an incon
  24. Ken Sharp
    Ken Sharp
    Thanks everyone for their input... So I ran it to temp double checked the timing.. put a vacuum gauge on and she is about 29-30.... I disconnect the pcv valve from the front of the carb and she jumps to 39-40... threw it in gear without the pcv hooked up and the ****** on the carb open and she didn't die in gear.... any ideas?
  25. Moriarity
    Moriarity
    SUPER MODERATOR
    sounds like a defective or the wrong pcv valve.... 40 inches of vacuum? I don't think that is possible. most gauges only go to 30, your car should idle at 15-20 or so
  26. Ken Sharp
    Ken Sharp
    Sorry.. reading the wrong ring on the gauge... it went from 12 to 16 after opening up the pcv valve.. leaving the ****** in the carb open and not plugged
  27. Moriarity
    Moriarity
    SUPER MODERATOR
    let me get this straight, you left the ****** on the carb open as in you did not plug it and it got better???
    Desoto291Hemi and Johnny Gee like this.
  28. Ken Sharp
    Ken Sharp
    Like I said I'm Flippin confused... yes..
  29. Moriarity
    Moriarity
    SUPER MODERATOR
    that makes no sense at all. only thing it could be is the carb is super rich? and it needs the extra air to run? better look at the carb. is there fuel dripping off the venturis at idle? do your eyes burn when you stand behind it when it is running? what happens when you plug the carb port for the pcv?
    SS327 likes this.
  30. Ken Sharp
    Ken Sharp
    Fuel isn't dripping... smells rich but if you plug the port it dies
