Technical 327 problem
Discussion in 'The Hokey Ass Message Board' started by Carl Wurfel, Nov 7, 2018.
  1. Carl Wurfel
    Carl Wurfel
    I realize this question can have many answers and I’ve read a couple other threads but they are slightly different from my issue.
    I rebuilt a 327 and had the crank ground and block bored and used all new parts other than that.
    I used platigauge and followed a book step by step, the crank still turned nicely when I torqued the Rod journals but as I added each additional part the motor got progressively tighter, it still turned though but felt tight when it sat overnight, then turned fine as I moved it. Once I added the positions it was fairly tight but turned.
    I installed it, moved it a bit with the starter, then it sat for three months, now won’t turn. Brutal. I’m losing patience I’ve been very careful building it. I’m pulling it but feel like I won’t find any problem.
  2. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    Can you clarify this a lil bit?
  3. Budget36
    Budget36
    I'm thinking he means pistons.
  4. 302GMC
    302GMC
    from Idaho
    If you can't turn it, you'll find the reason. Don't screw with it any more until you tear it apart, thus saving your new parts if not yet ruined.
  5. Carl Wurfel
    Carl Wurfel
    Installed it into the truck I’m building I mean, yes once it was fully together it did turn but was tight.
  6. Carl Wurfel
    Carl Wurfel
    Ok hopefully I didn’t ruin it.
  7. F-ONE
    F-ONE
    from Alabama
    The first thing that comes to mind is incorrect ring gap. Did you "gap" the rings for each cylinder? The rings must have some clearance end to end, Otherwise they will be too tight or cannot expand at operating temperature..
    There could be other problems, some being mistakes in machining, parts or ***embly. The only thing you can do is take it apart check and measure everything. Hopefully you'll find the problem quickly.
    The worse thing you can do is try to free it and run it. It needs to come out and come back apart.
    Hollywood-East likes this.
  8. DDDenny
    Main caps in order?
    56premiere likes this.
  9. mad mikey
    mad mikey
    Did you install new pistons? Rings? where clearances checked, ring gap, piston to cyl. wall? Rod side clearances ?
  10. Hnstray
    Hnstray
    from Quincy, IL
    What did you use for ***embly lubrication?
  11. jetnow1
    jetnow1
    from CT
    Where was it stored for the few months? Was the engine sealed up to prevent entry of moisture or rodents? Humidity
    and or mouse pee can cause a lot of rust on a short time.
  12. Carl Wurfel
    Carl Wurfel
    I started filing the rings but the guy who sold to me said not to because they are factory gaped already, he said you just make burrs and take off the moly coating.
    I used that thick red stuff by Comp Cam , I don’t really like it as it slides off all the parts I noticed and is sticky, I think it adds to the problem.
    Main caps are in order, piston wall clearance was not a problem I checked. It’s going into this which has been sandblasted and painted dark red.
    Hnstray likes this.
  13. Carl Wurfel
    Carl Wurfel
    Stored in clean garage no vermin and heated. That didn’t happen.
  14. squirrel
    "hard to turn" means different things to different people. It does take some experience to get a feel for what is ok, and what is not.
    When ***embling a V8 engine, I can usually turn the crankshaft by hand, pushing on a counterweight, till I get about half the pistons in, then it takes a wrench or pry bar to turn it.
    There are lots of things that you could have done wrong, or maybe it's all ok and you just expect it to be easier to turn. It's really hard for us to tell, with the info you gave us.
    On the rings--if they are normal replacement rings, you should not need to file them, although you do have to check the gaps to make sure they are the correct ones, and were made correctly. If they are file to fit rings, you definitely need to file them.
  15. pitman
    pitman
    Once built a 265" w/one (slightly bent) rod.
    Took apart, started over, carefully turned crank after each rod/piston ***y was coupled. (Believe I used an in-lbs torque wrench on crank bolt). ID-ed the bad actor!
  16. anothercarguy
    anothercarguy
    A couple days or weeks worth of time invested now to investigate the problem will dissapear once your project is back on the road. Take a step backwards to find the issue.
    Carl Wurfel likes this.
  17. Carl Wurfel
    Carl Wurfel
    Once all the pistons were in I could turn it with a socket on the crankshaft but was tight, I did check the pre gapped rings and would have filed off .001 or .002 but again my store guy said no need. This is the stuff that I used in it.
    I realize there are 200 possible problems and would have dissembled it before dropping in the truck but my research said, some motors are tight.
  18. Carl Wurfel
    Carl Wurfel
    Yes I will slowly dissemble to see if a free up action happens. Rods were new though I guess your saying new doesn’t mean straight
  19. Carl Wurfel
    Carl Wurfel
    Actually I don’t think I could turn it by hand with all the pistons in without rings, I’m sure I needed a bar.
  20. JC Sparks
    JC Sparks
    from Ohio
    If you have a bolt in the end of your crank use a torque wrench to see how many foot pounds it takes to make it turn. Then post the results up.
    mad mikey and pitman like this.
  21. BigDogSS
    BigDogSS
    from SoCal
    Pistons installed WITHOUT rings?? I'm not understanding....
  22. pitman
    pitman
    My 265 had gone off a bridge, at least one cylinder had a drink. The rod told the story.
    You could build up the block/crank ***y, measure torque to rotate, then add cam and chain.
  23. squirrel
    If you installed all the rods/pistons without rings, and it is hard to turn, something is wrong!
    Did you have the rods resized?
    Did you stamp numbers on them before you took it apart? mismatched rod caps is a likely problem, but we weren't looking over your shoulder when you did the work, we don't know if you kept them in order, or not.
    I've encountered a bent rod once, it was in a set of "remanufactured" rods I bought years ago. Now I'm pretty good about only using rods that were in a good core engine, as a set. I get them resized and balanced as needed, this depends on the application.
    Tickety Boo and Hollywood-East like this.
  24. KJSR
    KJSR
    from Utah
    Using the cam and lifter lube will make it hard to turn. That stuff is way too thick for the bearings (IMO). The heat will play into it as well......if you built in the summer but now you're trying to crank it when its cold, the cam lube has an even worse effect.
    karl share likes this.
  25. Bearcat_V8
    Bearcat_V8
    from Dexter, MI
    I just put together the lower end of a Stude 259 with new rings and bearings. I installed the crank and it turned freely. As I installed the pistons it got progressively harder to turn. It finally refused to turn when I got all of the pistons installed and the rod caps torqued. Of course I tore it all down and started all over again, checking everything while I re-***embled it. All the rod journal clearances and ring gaps were good. Same result, will not turn!
    I broke down and purchased a crank snout socket from Summit. I lubed the bores and rotated the motor with a long breaker bar. The more I rotated it the freer it moved. I think it was just the rings against the fresh cross-hatch in the bores. I have not installed the motor in anything so I can't say how well it runs yet.
    One last thing, the ring manufacturer (Hastings) recommends straight weight motor oil on the pistons and rings during ***embly. I don't know if that will really make any difference.
    Hnstray and pitman like this.
  26. squirrel
    Yes, I guess I didn't think about that...it is rather thick! Cam and lifter lube is good for cams and lifters. Engine oil is good for some other parts of the engine, and will stick around longer than some guys realize.
  27. pitman
    pitman
    The additives, viscosity mods, aren't lube. Suspect Bearcat's post advises well. :)
    Hnstray likes this.
  28. DDDenny
  29. Presume you oiled the pistons and rings before installing?
  30. finn
    finn
    Are the rods facing the right way, with the chamfer facing the crank pin fillet?
    Deuces, 34toddster and sunbeam like this.
