327SBC or 324OLDS Which is better?
Discussion in 'The Hokey Ass Message Board' started by MATACONCEPTS, Oct 24, 2012.
  1. MATACONCEPTS
    MATACONCEPTS
    Im gotta build me another car. I got a A frame, 28 Ford Cowl, & some parts. Thinking about a Woody, HomeBrewed style.
  2. terryble
    terryble
    from canada
    That is a very interesting question! Both are traditional, the 327 is one of the finest performance motors ever made and (in mt humgle opinion) the 324 is one of the finest running, smooth and attractive motors ever made. Your frame is set up for SBC and older Olds engines are a bit of a pain to mount sometimes. You are very lucky to have a choice between two of the best motors built.
  3. Can't really go wrong with either one- if you absolutely want speed, then use the 327, otherwise use the Olds for a little more "wow" factor
  4. teejay99
    teejay99
    Chevy makes some versitile and potent small blocks ....I've had them and would never bad mouth the Chevy motor . Trouble is , virtually EVERYONE runs a Chevy in their Ford rods . When I look on Carsonline or similar sites , must be 90% sbc crate motors .
    If it was my money , and it's not , I'd go with the Olds , so as not to be the same as everyone else . That being said , I prefer a Ford in a Ford but that's another story . :)
    T
  5. terryble
    terryble
    from canada
    Sorry....(in mt hugle opinion) should read (in my humble opinion) damned old fingers on wrong keys and not rereading before sending!
  6. Jimv
    Jimv
    50/50 but that Olds engine looks so ****in cool!!Only trouble with the olds is that sometimes the rockers suffers for oil a little.
    Keep us posted on the build.
    JimV
  7. tubman
    tubman
    Cheapest - Chevrolet
    Fastest - Chevrolet
    Easiest - Chevrolet
    Lightest - Chevrolet
    Coolest - Oldsmobile
  8. 4t7flat
    4t7flat
    The Old's is not just a little WOW factor,but a huge WOW factor. Like,"WOW" this one does not have a stinkin Chevy in it.
  9. 62dartman
    62dartman
    ^^ x2
    cool factor always wins!!
  10. 327Eric
    327Eric
    technically- the chevy is the better engine- look at how long it was produced, vs the olds engine. In my opinion, the chevy is the better engine. In my car the chevy is the better engine. If I ever built an early rod, The Olds would be my choice. It can run Hard, but will be a bit more expensive. The cool factor would be priceless. Drop 3 two's on it, and a 37 LaSalle box behind it, and have fun. My .02
  11. firingorder1
    firingorder1
    Ask Kenny Safford which one he's prefer.
  12. Bruce Lancaster
    Bruce Lancaster
    "Cheapest - Chevrolet
    Fastest - Chevrolet
    Easiest - Chevrolet
    Coolest - Oldsmobile "
    100% correct! Weight dif is going to be around 200 pounds, a LOT to hang in the front of a Model A.
    Chevy carefully detailed with period intake (lots of choice there, too), valve covers, proper wiring and detailing, could bring back a lot of the coolness points lost to the Olds.
    Another factor...324 olds is really toodamnsmall in displacement to justify its weight, but can itself be built much larger or can be replaced with 394...as is, you are getting big block weight and small block displacement.
  13. ol fueler
    ol fueler
    The OLDS has my vote --hands down. Never ran a sbc --never will --Might be a good motor--- but EVERYBODY has one-- might as well drive a 4 door grannies car as have a cookie cutter SBC!
  14. Fogger
    Fogger
    I've had both and the difference between them is the Olds costs more, weighs a lot more and can't make the power on a similar budget. But the Olds is not as common and a 324 is a desirable piece for a hot rod.
  15. MATACONCEPTS
    MATACONCEPTS
    There it is. Thanks for make sense of it all. Olds wins.
    Maybe I should put the Olds in the A?
  16. MATACONCEPTS
    MATACONCEPTS
    New question, Olds or 4-banger? Man, life can be tough sometimes.
  17. Saxman
    Saxman
    Yep! That's it!
  18. Jay Tyrrell
    Jay Tyrrell
  19. dad-bud
    dad-bud
    SBC is definitely a good motor, but the OLDS will be cool. 4 banger will be cheaper to run, but really............!!!!!!?????
  20. 57 HEAP
    57 HEAP
    That's not a question, it's a cry for help!
    324 Olds over SBC.
  21. F&J
    F&J
    Just be damn well prepared with that SBC if you run against a Ross built Olds, or the Olds built by Dave's Auto Machine, in Dave50's coupe. ;) Those two guys got something up their sleeves:rolleyes:
  22. Dave50
    Dave50
  23. Dave50
    Dave50
    If you go with Tony (Goatroper02) Ross Racing Engines you`ll have a olds that eats chevy`s no problem ,now there are alot of variables and you have to do it right like anything. Are they cheap No, either is a good steak! Or good work, And trust me if you think you can your wrong! Tony has put alot of time and money in his program. He also has stepped up to the plate and have made many Parts for the Olds as did other companys for the SBC. The only things up our sleeves is dirt from hard work! I would like to take all the credit for my olds motor but what I have I couldnt of done with out Tony! Thanks again Tony! The 303 runs good! I can build you whatever you want olds,caddy,chevy, ford its what we do.
    So to answer your question it all depends on how uch you want to spend and where you want to find a motor on craiglsist or have a custom built engine for you and your needs.
  24. Deuces
    Deuces
    Ummmm..... What's a 4 banger????:confused:
  25. oldiron73
    oldiron73
    from WISCONSIN
    Well said!
  26. Niether is actually better they are just different. Both engines in the same condition will give you the same amount of enjoyment.
    Choose one build it and enjoy it.
  27. Buzznut
    Buzznut
    I agree...however, there are 20 different ways to make a 327 look cool, besides the fact that they are already pretty cool to begin with. PLUS, I don't think a true 327 ever gets the same reaction that a basic 350 does.
    Sure, but if you do the same exact type of build with a 327 (probably for cheaper I might add) the Olds won't be able to touch it.
  28. slider's house of kustoms
    from idaho
    Banger: 6 volt, uncut bones, cross steer, square head or flat head screws only, no channel, light chop, fenders, lacquer paint, leather accents, oe knobs and gauges, single tapered exhaust bologna cut
    Olds: 12 convert, cut bones, hoop steer, chrome goodies, channel, light chop, no fenders, single stage paint, mole hair. vintage s&w gauges and a few oe knobs, 1 1/2 straight pipe to the rear.
    Chevy: 12 volt generator!, radius rods, hoop steer, BUnch O finn stuff, 3 or more carbs, channel, little more aggressive chop stress little more, no fenders base/clear CRAZY TIME!!!! Flake or Candy!!! tuck n roll, s7w gauges in and outside, candy stripe knobs, fenton split exhaust 4 pipes 1 1/2 at the rear chrome rib tips.
    I know i really doesn't help but hey thanks for letting me dream during lunch :)
  29. swe64
    swe64
    small jurnal chevys is my favorite engine i been driving it in my -27 sinse 1992 with a 283 350 hp mec cam and powerpack heads but crate engine suchs
    go for old iron olds
  30. Speedy Canuck
    Speedy Canuck
    Rocket for the win! :D
