Projects '33-'34 Firewalls
Discussion in 'Traditional Hot Rods' started by Retro61, Feb 17, 2014.
  1. Retro61
    Retro61
    Hey Fellas, I'm putting a 312 Y-Block,with a Spalding Flame Thrower Distributor, in my 5- Window, and would like to see some of your Firewall modifications. I've got a really nice Firewall and really don't want to modify it any more than I have too. I want to keep as much of the original as possible!
    Show me what you've got!!
    Thanks!
  2. 37 caddy
    37 caddy
    from PEI Canada
    What I am planning to use on my 33 is a firewall from a 35-36 ford,it has a indentation at the rear for a distributor?,it is not really a dizzy indentation but it looks like one,it also has the big ribs in it like a 33 has,i think I can put it in and it will look very original?I don't have any pictures yet,but I think it might be a good place to start. Harvey
  3. Retro61
    Retro61
    Cool-Thanks! I have a really nice xtra Firewall I can incorporate with my original, if I have to. I just hate to Butcher the Stock one anymore than I have too.
    I Love the looks of the original!
  4. This is one we did for a sedan with a 348. Shrunk back the body lines & made a removable insert that was riveted in with aviation rivets. Not sure if this is the kind of look your going for though.
  5. studefreak
    studefreak
    Here's what we did on mine .you can kind of get the idea; hard to see with the motor in it
  6. Retro61
    Retro61
    Cool stuff-Thanks guys! It helps!
  7. cad-lasalle
    cad-lasalle
    from grafton nh
    I'm just finishing up a 34 that I used a 35 firewall in. The 35, being wider, need some work on the edges to fit. It looks original at first glance and leaves room for most distributors.
  8. timwhit
    timwhit
    The 35 and up pickups is a source for firewalls also. Maybe the same as car, real close in appearance maybe easier to find??? Tim
  9. Kirk Hanning
    Kirk Hanning
    I utilized the pieces that I cut out then took a donor firewall for the ribbon surround adding a return however deep necessary. Rivet in and done.
  10. Retro61
    Retro61
    Awesome work Kirk! I dig it! I too, want to keep the stock Ribs as much as possible, and I don't mind cutting up the other Firewall, that's what I got it for-haha
    Thanks
  11. ss34coupe
    ss34coupe
    Here's a 33 Ford coupe. The pics shows the firewall modification to fit a 331 Cadillac engine. Not difficult to do, but I did not like cutting into a cherry stock firewall.
  12. Kirk Hanning
    Kirk Hanning
    It's a good thing that I can cut & weld metal better than trying to post a pic... Even if it is upside down (roll eyes).
    Here's another shot with everything in place. There is enough room around everything to p*** a finger thru.
  13. Retro61
    Retro61
    Thanks guys-the Wheels are Spinnin now, hahaha
  14. general gow
    general gow
    MODERATOR
  15. TheKeystoneKid
    TheKeystoneKid
    from Allentown
