33-34 Ford 5 Window Coupes
Discussion in 'The Hokey Ass Message Board' started by 35mastr, Sep 26, 2010.
  1. 35mastr
    35mastr
    from Norcal
    What is the difference between them?
  2. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    Hood and Grille Shell as well as a few other minute details I'd think. 33 had one handle on the hood and '34 had two.
  3. general gow
    general gow
    MODERATOR
    '34 has the pocket at the back of the window opening so that the window can go back first before it goes down, creating a sort of vent window.
  4. M.Edell
    M.Edell
    34 is one number higher than 33...
    Kurt Ljungkvist likes this.
  5. 58fed
    58fed
    The interior door handle is in the middle on one year and to the front on the other year....I forget which is which. Also, the '34, when the window came back a little, that was for the smokers.
  6. Fenders
    Fenders
    Curved louvers on the 33 hood sides, straight on the '34.
  7. 35mastr
    35mastr
    from Norcal
    No ****. 3 posts in and we already have a wise guy.:rolleyes:
  8. M.Edell
    M.Edell
  9. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    Whoa a lot more differences then I thought. Good info.
  10. M.Edell
    M.Edell
    You and me both..Whats this all about George? Inquiring minds want to know?
  11. Comet
    Comet
    33's have smooth inner fender wells, 34's have 3 beads that form a "V" shape. Although I understand some late 33's had them as well.
  12. bill3337
    bill3337
    There's about 65 difference, although some are very minor. Starting at the front, the '33 bumpers have bolts that are 22" apart, '34's are 26. The '33 grilles are finer framed and curved as are the hood louvers. The '33 hood tops have a raised bead at the front. The '33 front fenders and inner fenders have a poker chip sized recess on the edge that fit together, the '34 doesn't have this. The '33 headlights and cowl lights are slightly more bullet shaped. The '33 hood latch has only one handle and the recess in the firewall is different shape than a '34. The '34 has notches in the firewall to hold the hood when it is open, the '33 doesn't. The '33 cowl vent has no screening, the '34 does. The '33 dash has a removeable instrument panel section, the '34 doesn't. The '33 ashtray has a hinged lid. The early '33 inner door handles are mounted close to the front and have a looped ring door pull. The '34 doors have a vertical bar to accommodate the vent window operation that the '33 doesn't have. The '33 door lock is the same as a '32, while the '34 is different. There's lots of other minor differences, but those are the most significant that I can remember at the moment. Bill
    zz29 likes this.
  13. Whoa. We just got taken to school. Thanks Bill!
  14. M.Edell
    M.Edell
    Yeah, Yeah...What he said...:eek::D
  15. yekoms
    yekoms
    Bill covered it damn good...
    Formed into the cowl there are two beads to support the hood lace. On a 33 the beads are continuous on a 34 they are interrupted at the screw holes.
    Smokey
  16. 35mastr
    35mastr
    from Norcal
    This is a real good schooling. Never even thought there were this many.
  17. clubcoupe37
    clubcoupe37
    a lot of good info. thx
  18. Dennis Lacy
    Dennis Lacy
    The sheetmetal and interior differences have been covered well. Correct me if I'm wrong, but werent 33 sun visors like a 32 in that they only hinged down, whereas 34 they hinged down and pivoted so that they could be moved to shade the door window as well?
    There are also several differences in the ch***is:
    - 33 front crossmember and radiator mounting brackets are different than 34 which were substancially "beefed up."
    - 33 front shocks were mounted inside the frame, 34 on the outside. For both years the rears are mounted inside.
    - 33 pedals mount with 3 bolts, 34 pedals mount with 5 and the pedal shaft is about an inch higher and the pedals themselves are about an inch shorter.
    - 33 spring leaves are tapered at the ends, 34 are cut straight.
    - Early 33 steering gear ratio was 13:1 (like 32), later 33 and all 34 was 15:1.
    - I believe the styling of the front brake backing plates are different between the two years as well?
    - 33 engine used the single throat Detroit Lubricator carburetor (like 32), 34 used dual throat Stromberg "97" carburetor. There are some other engine differences that I can't recall.
    My Dad has had several '34 Fords over the years that have interesting "transitional" features. His roadster has smooth rear wheel wells. His Sedan Delivery had the forward mounted inner door handles like 33, yet had the correct '34 rope door pull.
    His 5W was built in November 33 and featured many 33 items such as:
    - Inside mounted front shocks
    - Narrower front bumper bolt spacing
    - Longer headlight and cowl light buckets
    - Forward position inner door handles
    - Dashboard with seperate instument panel, although the panel was flat and woodgrained like a normal 34 would be
    It's amazing how many differences there are for how similar the two years are. it also goes to show that Ford didn't let anything go to waste!
  19. 35mastr
    35mastr
    from Norcal
    Wow great information. Keep it coming.
  20. 33 radiator has pocket built into the upright supports to hold the hood corners when the hood is open, 34 hood sat on a indentation on the cowl lip.
    33 and early 34 doors, the inner door handle is forward, late 34 inner handle is middle of door.
    34 cowl has an upside down crescent punched in the cowl side for the hood latch, 33 had a single round hole.
    There are major differences in the header panel where visor would mount.
  21. 117harv
    117harv
    Which year is more desireable? Can the curved louver 33 hood be made to work on the 34?
  22. Lord Purple
    Lord Purple
    The one you are offered at a price you can afford! :D
    L.P. (With wise guy hat on)
  23. Hot Rods Ta Hell
    Hot Rods Ta Hell
    34 inside door garnishes are slightly different than 33's, to accomodate the 34 "rollback" feature.
    Also, a few very early 33's came with "skirtless" fenders (much like 32's the had no skirt following the whellwell opening).
  24. ss34coupe
    ss34coupe
    Both the 33 and 34 are very desireable....but I have always thought it is best not to mix the parts that are different (like the hood). Keep it a 33 or 34, not some combination of the two years.
  25. D ROD
    D ROD
    from New Jersey
    I beleive the instrument cluster on a 33 is engine turned and not on 34, also there are chicken tracks in the rear wheel wells on 34
  26. gearhead1952
    gearhead1952
    I put 33 hood sides on my 34 5w. They are one inch longer at the top where they meet the grille. Hood latching is different but can be made to work. As to which year is better is a personal choice, I like them both. :)
  27. lopezz2
    lopezz2
    from bangalore
    <!--[if gte mso 9]><xml> <w:WordDo***ent> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:punctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <w:DontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDo***ent> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> This is a wonderful opinion. The things mentioned are unanimous and needs to be appreciated by everyone.
    Lopezz.
  28. 2deuces64
    2deuces64
    One more-The inside header tack strip on the 33 is wood and the 34 has a fiber rope.
  29. Horn
    Horn
    Isn't there also a difference on how the door hinges attach to the B-pillar? On 33 they go "inside" the pillar, and on 34 they mount on the outside.
    To make things even more confusing, my 34 Cabriolet have a 33 style door hinge mounting and rear inner fenders and all the rest is like on a 34. Does anyone know why?
  30. SUNROOFCORD
    SUNROOFCORD
