33-34 ford pickup radiator support rod question
Discussion in 'The Hokey Ass Message Board' started by skidmarks, Feb 23, 2009.
  1. skidmarks
    skidmarks
    from USA
    tried the search function but couldnt find any info. anyone know what the overall length of the radiator to firewall support rods ? also if other years fit ?
  2. Bruce Lancaster
    Bruce Lancaster
    Life should be so simple...I found a '28-36 parts book first, so used that. I now realize a later book would have shown even more fun variations!
    Here's the '28-37 scoop, hastily scribbled. I thin A one is a union of 2 earlier numbers, and note that rods were alread being discontinued and replaced by other ones, presumably with a hacksaw in some cases.
    Model A A-8133-AR 26" (the later one, discontinued by '36, was 25 5/8")
    B B-8133 30 3/8
    18 18-8133 29 3/4
    40 40-8133 31 '33-4 passenger
    46, BB 46-8133 24 5/8 '33-4 pickup and big truck make from Model A part above
    48 48-8133 AR and BR 32 3/4, 32 13/32 (!) 1935 pass, early and later
    68 68-8133 AR and B 2 versions '36 passenger, lengths not given
    '35-6 trucks, 29 1/8, cut from 1936 pass
  3. Petejoe
    Petejoe
    from Zoar, Ohio
    On mine I found two issues.
    I didn't run a hood and found the radiator/grille angle looks better with longer than stock rods. The stock rods tilt the radiator to a different angle than the cowl.
    I suppose it really depends if you are running a stock or aftermarket hood.
    In order to match the hood edges correctly the grill/radiator needs shifted back quite a bit. If your still in question..pm me and I will measure my length since I just fit it with a aftermarket hood.
  4. Bruce Lancaster
    Bruce Lancaster
    Let me know if the catalog is right...24 5/8 seems really short. I never noticed before that B and 18 were slightly different, even.
  5. Bruce Lancaster
    Bruce Lancaster
    I do know that the '33-4's are about the hardest to fit with an engine because the radiator comes back so close to upper front of engine.
  6. i think all the repo radiator rods come long and you cut them to fit
  7. richie rebel
    richie rebel
    make your own, very easy,either 5/16 or 3/8 aluminum rods,home depot or sears......richie........
