Technical 33-34 ford transmission mount
Discussion in 'Traditional Hot Rods' started by Fastcheck, Aug 27, 2014.
  1. Fastcheck
    Fastcheck
    from Alabama
    Am I missing the clam shell for this
  2. Dak Rat
    Dak Rat
    from NoDak
    Yes, you are missing the split outer cover.
  3. alchemy
    alchemy
    A actual 33-34 rearend didn't have a split clamshell. It was one piece and not removable from the torquetube. But if you are running a later rear, the later split clamshell will fit right on this mount.
  4. big duece
    big duece
    from kansas
    I have one off a '36 if you need one.
  5. Fastcheck
    Fastcheck
    from Alabama
    Im using a
    31 rear end
  6. general gow
    general gow
    MODERATOR
    A 31 rear end in a 34? Why on earth would you do that?
  7. Fastcheck
    Fastcheck
    from Alabama
    Building AV8
    From 1931
  8. Fastcheck
    Fastcheck
    from Alabama
  9. Fastcheck
    Fastcheck
    from Alabama
    This it the chasis i will be using
  10. Fastcheck
    Fastcheck
    from Alabama
  11. Fastcheck
    Fastcheck
    from Alabama
  12. Fastcheck
    Fastcheck
    from Alabama
  13. alchemy
    alchemy
    Doesn't the A rearend have a clamshell with 6 mounting bolts? Set the front bell of the torquetube up to the '32 inner clam and see if it has the same shape (I bet it does). If so, you could probably cut the stock A 6-bolt clamshell off and use a '36-48 split clamshell to hold the A rear to the '32 mount.
    Before you do all this, you might want to do some measuring or mock-up to be sure the stock length A rearend will position the V8 engine and trans in the correct location to your firewall and radiator. If they are not a good fit, it might be wise to position the engine first, then work your way back. Might end up shortening a V8 rear and torquetube to fit, instead of shortening the A. This will give you a better rearend anyway.
  14. Bruce Lancaster
    Bruce Lancaster
    With a '31 rear you do indeed need a clamshell from '32-48...inner shape is fine, but the A bolt holes are all wrong.
  15. Fastcheck
    Fastcheck
    from Alabama
    Cool thanks
    Bruce do yoh think the A driveshaft length will work
  16. Bruce Lancaster
    Bruce Lancaster
    For using the A shaft, you just use it as the ground zero that sets the location of everything else...
    Have rear in place in ch***is, put in the part at top of front spring U-bolts that has hole for handcrank, and lower in your engine/tran and bolt to Ujoint stuff for your mockup. You want the Ujoint hookup to be at same height in relation to frame rails as stock, so measure that right now while it's together. Get that height located, put front of engine so center of crank pulley is at right level to accept handcrank through that hole, and that's your axis mundi for the car. Put on stock radiator or approximate its location to be sure you have not made something unworkable, think about where your firewall will be and what minor t******* might be needed. If everything seems do-able, put in engine mounts (like Hurst A-28's?) to support engine mounts at right al***ude.
