Technical 33 bb dump truck
Discussion in 'Traditional Hot Rods' started by old chevy nut, May 13, 2017.
  1. old chevy nut
    old chevy nut
    from va
    can anyone tell me if the front fenders on a bb big truck are the same as a pickup? i have read that they were same fenders
  2. finn
    finn
    Larger wheel openings
  3. sololobo
    sololobo
    I don't know of any model or make where the fenders are the same. On trucks like my 66 Chevy c-10 half ton, the cab is the same on many of the models, doors exchange, gl*** and just most cab parts. As mentioned bigger wheel openings are the bad deal.
  4. old chevy nut
    old chevy nut
    from va
    thanks i thought the same thing but ive seen post that some say the 33-34 pickup and big truck fenders are the same?
  5. xlr8
    xlr8
    from Idaho
    With some of the big tires people are using nowadays, like 20 inches, they might be usable though.
  6. 1932. 1933, 1934 Ford Pickup & Commercial Fenders
    1932 Ford Pickup & Commerical Fenders are the Same & Will fit Both.
    1933 & 1934 Ford Pickup & Commerical Fenders are the Same & Will fit Both.
    1932 & 1933, 1934 Pickup & Commerical Fenders are Different. 1933, 1934 Pickup Fender have a Die Stamped Hup on the mounting Fender Frame Rail sheet Metal, where it bolts to the Frame. This is for the Shock Arm To travel up & Down. If You don't use the Stock Shocks on the 1933, 1934 Ford Pickup. These Fenders will then fit. Hope this information helps. Best Regards Respectfully BigDTexasKid
  7. When you said larger wheel openings I am sure you meant for the spare tire in the fender. Many people thought the reference was to the wheel opening for the wheels on the ground. The fenders are the same except for the opening for the fender mounted tire.
    Charlie Stephens
  8. sloppy jalopies
    sloppy jalopies
    IMO... yes they are the same... '35 was the first year for larger wheelwells...
    both of the '33 -'34 truck frames had more of an arch between the grill and cowl than the '32s..
    '33 + '34 truck fender braces are the same...I think '32 car and truck are the same but are different than the '33 -'34 trucks ...
  9. falconsprint63
    falconsprint63
    from Mayberry
