Projects 33 chevy 3w....time for a cool change
Discussion in 'Traditional Hot Rods' started by tb33anda3rd, Feb 11, 2014.
  1. tb33anda3rd
    tb33anda3rd
    thanks! once i got everything fitted and made the inner steel supports, i took the doors apart. i s****ed off all the tar paper stuff, and sandblasted the bottom edge that had rust. i found three small pin holes on the p***enger side and a dent that was filled with lead on the driver side. i had noticed that the wood on the driver side looked burnt [see photo post 440] now i know why. now that the wood is out i could grind the lead out and and tap the dent out. on the p***enger side i welded the pin holes and ground them smooth. DSCF3613.JPG DSCF3615.JPG
    volvobrynk likes this.
  2. tb33anda3rd
    tb33anda3rd
    i painted the inside of the doors, the new pieces of wood and the steel inner supports. DSCF3617.JPG DSCF3620.JPG DSCF3619.JPG
    TFoch and volvobrynk like this.
  3. Lilred36
    Lilred36
    Nice work, been following the post for a while. Is that a '36 Chevy cab I spy in the second picture???
    tb33anda3rd likes this.
  4. tb33anda3rd
    tb33anda3rd
    thanks, glad your following!
    no that is a '37 i am restoring for a customer. worked out good, i had a '38 i resto-rodded last year so i ended up with a bunch of good parts.:)
  5. ct1932ford
    ct1932ford
    Stopped by tb33anda3rd's today and was glad to see him working feverously on the Coupe!:D Some photos of the car and man:rolleyes:
    Ted & Erie 001.JPG Doors look much better with a clean camera lenso_O
    I just figured out why you don't see Chevy Hiboys. They sat over the frame already:eek:
    Car is in amazing condition and it looks great. Brings me way back 53 years when I first had a ride in it with Ted's Dad.:cool:
    gwhite, INVISIBLEKID, TFoch and 2 others like this.
  6. tb33anda3rd
    tb33anda3rd
    finished putting the doors back together, cleaned a lubed the latches, and lubed up the regulators. i used what i guess is todays equivalent of the tar paper they had on the inside of the door. it is a foil with a rubbery layer with a adhesive on the back. i bought the six inch wide rolls at homecheapo for $17 a roll. i used one roll with about 4" left over. i heard this stuff reduces heat and noise DSCF3622.JPG DSCF3624.JPG
  7. blowby
    blowby
    from Nicasio Ca
    You need more tools there. Only three drills, two grinders and one DA :)
  8. ct1932ford
    ct1932ford
    You have not seen this guy work!:eek:
  9. tb33anda3rd
    tb33anda3rd
  10. tb33anda3rd
    tb33anda3rd
    you should see the floor and the workbench....:D:cool:
    31Vicky with a hemi likes this.
  11. See, them nasty little *******s hang out at your shop too.
  12. tb33anda3rd
    tb33anda3rd
  13. tb33anda3rd
    tb33anda3rd
    got the running boards back from the blasters, lots of little holes, spent the weekend. welding them up. took my time but i ended up with a twist to the boards. it happened as i welded up the center "rib" so i hammered the welds till the panel flattened out. took some time but they lay flat. DSCF3641.JPG DSCF3642.JPG
  14. tb33anda3rd
    tb33anda3rd
    i also made new filler pieces for the upholstery on the door to tack to.
    i made a couple blocks that connect the out side vertical support on the door to the new bottom cross board.
    the later chevy doors i have worked on had a cross brace bar that ran from the upper hinge area to the back lower side of the door. although my doors are now tight and aligned i wanted to add them. i used screen door braces that had a turn buckle in the middle. i put them in.....but i don't know if i like it.....i don't need them.....they are already done and won't hurt anything if they stay in.
    opinions?
  15. tb33anda3rd
    tb33anda3rd
  16. ct1932ford
    ct1932ford
    I would just put lock nuts/star washers on the turnbuckles so they cannot loosen up over time. Other than that carry on!:rolleyes:
  17. tb33anda3rd
    tb33anda3rd
    good idea!
  18. The37Kid
    The37Kid
    Leave the screen door adjusters in, I love the sound of a screen door slamming shut, sounds like Summer. Bob
  19. ct1932ford
    ct1932ford
    Bob Bob Bob I think winter is taking it's toll on you!:rolleyes:
    volvobrynk and tb33anda3rd like this.
  20. blowby
    blowby
    from Nicasio Ca
    Is the window down all the way in those photos? If so that area would make a great storage pocket without the diagonal braces.
  21. tb33anda3rd
    tb33anda3rd
    good thought and yes the window is down all the way. i have a spot my dad just built into the package tray for the reg' and "personal protection" and the only other thing i plan on hauling is ***.:D:cool:
  22. tb33anda3rd
    tb33anda3rd
    pulled the head liner out today. my dad never thought the interior job was very good. it held up well but had a few "bad" spots. found a mouse nest and spent most the morning pulling staples and tacks. DSCF3669.JPG DSCF3670.JPG DSCF3672.JPG
  23. tb33anda3rd
    tb33anda3rd
    then i pulled the Julianos top kit i put on back in '83. i forgot how many pop rivets it had holding down the aluminum track. i had saved the original tack strip trim but i feel the Julianos kit is far superior. it uses a canvas cloth that tacks to the wood, then foam that is glued and trimmed then the vinyl top material that is held in by an aluminum track that is pop riveted down. the track is covered by a vinyl trim that resembles the shape of the original chevy 1/2 round trim.
    3wLarry likes this.
  24. tb33anda3rd
    tb33anda3rd
    the 8 wood strips were very dry and "crispy" so i removed them. they were made from 1/4" hardwood plywood. i also removed the front header board, both ends were "weak" and as shown in the photos i had riveted a piece of flashing to support the corners of the canvas. when i installed the top i did not remove the headliner so i did not realize how bad the wood was. DSCF3677.JPG DSCF3678.JPG DSCF3680.JPG
  25. tb33anda3rd
    tb33anda3rd
    DSCF3679.JPG i think these aluminum strips holding down the edge of the slats are factory. maybe?
  26. tb33anda3rd
    tb33anda3rd
    i pulled all the nails and then DSCF3682.JPG DSCF3683.JPG s****ed off the old glue and sanded around the perimeter. i wire brushed and spot blasted the inside and painted it.
    gwhite likes this.
  27. tb33anda3rd
    tb33anda3rd
    i also polished the chrome trim ring for the dome light. does anyone know if it is the original '33 dome light? just curios i like it wether it is or not.:) DSCF3685.JPG
  28. tb33anda3rd
    tb33anda3rd
    found a piece of hardwood plywood left over from a furniture/cabinet project. it is 3/8" but will actually work better. these are the pieces i will need to make, the front header, the rear slat tack strip support and eight of the slats [sample for width only]. DSCF3681.JPG
  29. ct1932ford
    ct1932ford
    This far may as well take 8" out of the top!:rolleyes: Remember I just got back from the Rolling Bones Garage.:cool:
  30. tb33anda3rd
    tb33anda3rd
    only 8"?
