Projects 33 Doll Build Page
Discussion in 'Traditional Hot Rods' started by 33Doll, Mar 20, 2020.
  1. 33Doll
    33Doll
    I love My Work place!
    Saved it!!!! WHEWW!!!
    What a relief! That stress is gone!
    IMG_0579.JPG IMG_0580.JPG IMG_0581.JPG IMG_0582.JPG IMG_0583.JPG IMG_0584.JPG IMG_0585.JPG
  2. brEad
    brEad
    Nice save on the running board. Looks perfect!
    Stogy, loudbang and 33Doll like this.
  3. 33Doll
    33Doll
    Got it Home with its twin they look beautiful again!
    boy that sure is a relief
  4. I have a similar repair to do on some boards I picked up. Car had slipped off of jackstand, and it put an upwards dent in the board. Very close to that location. Did you use wood or any other material to protect the rubber cover?
    Stogy and loudbang like this.
  5. 33Doll
    33Doll
    I taped a quarter inch thick piece of rubber to the bottom of the hydraulic ram and use that on the rubber side, to push it down a little bit and then I stuck a block of wood under it pushed a little more, then I used a br*** hammer on the bottom and a block of wood on the rubber part to push the dent out a little bit when I was done. Then I use the block of wood with the br*** hammer to straighten the edge.
    Hope that helps?
    Stogy, chryslerfan55 and loudbang like this.
  6. Yes, it helps. Was thinking about thick rubber to prevent running board cover from tearing. Now I know it should work. Thanks.
    Stogy, 33Doll and loudbang like this.
  7. 33Doll
    33Doll
    Should, I guess it might also depend how old the rubber is to? Just take your time, an ****yze how the dent formed in reverse in slow motion in your head.
    As you push, pull, tap. Etc.
  8. Don't know exact age, but they are repop boards, that the PO put on Craigslist after the jackstand altercation. The metal looks like it might be stretched a bit too, but I'll get to that once I start on the board.
  9. 33Doll
    33Doll
    I’m on a spending spree! I bought new wood! There’s one place in the country that still makes it as far as I know Cl***ic would products I think they’re in North Carolina, but I bought it through Macs auto parts they have everything!
    There’s a six month waiting list on some of the wood because they are so busy which is a good thing!
    (I ordered the rear window wood too)
  10. 33Doll
    33Doll
    Even though I restored some of these parts, I can always sell them and make some of my money back, when I’m done with the car.
  11. 33Doll
    33Doll
    The Gl*** showed up today!
    I’m stoked! Cant beat $465 For the whole car! And Thats with shipping!
  12. Maicobreako
    Maicobreako
    Well, I got all my gl*** for free, so.....
  13. 33Doll
    33Doll
    Ok...New Gl***!
    Or you cut your own?
  14. Maicobreako
    Maicobreako
    I know a guy ;)
    Stogy, RICH B and loudbang like this.
  15. 33Doll
    33Doll
    I’m starting to get out-of-control!
    I’m like an adult kid buying adult size toys!
    This is just some of it, there’s more coming, plus I have more around the garage! They’re talking about a big Covid thing again! So if I get on lockdown again I’ll just live in the garage! And be busy for a long time!
  16. RodStRace
    RodStRace
    Stock up on sandpaper and welding gas! :D
  17. 33Doll
    33Doll
    Welding Gas[emoji736]
    Sand paper[emoji736]
    Wire Wheels[emoji736]
    Cut-off wheels[emoji736]
  18. loudbang
    ALL THAT will keep you busy for awhile. :eek:
    VANDENPLAS, Stogy and 33Doll like this.
  19. 33Doll
    33Doll
    Man! I can’t wait to get the motor in!
    I love My new OTB breather. And my Arias Components “Surfer” Cal-Custom style scoop!
    You CAN dress A flatty 60’s Style!
  20. 33Doll
    33Doll
  21. 33Doll
    33Doll
    So, my Pops put the original style mechanical pump on the engine so he could run the vacuum wiper on hills and not lose vacuum and such. So I started looking into this whole thing, and decided that it’s basically reengineering half the engine just use a stupid vacuum wiper!
    Because I can’t use the stock throttle I’d have to get a s**** cable, I have to modify the breather tube up front because it hits the bigger water necks, and had to Jerry rig the carburetor to fit the vacuum port on the mechanical pump.etc....
    So basically I could eliminate all that by just using electric wiper from speedway, that way I can hook the throttle back up the way it was before, I can plug the front breather hole With a freeze plug, run the rear breather for better flow, and the PCV up front will hook up to the back of the carburetor with a hard line and just put a Electric fuel pump on it like it had before!
    So I started reading up on Flathead’s, and saw an article or thread on the ham about plugging the fuel pump hole several different ways, so my way is just to flip the fuel pump rod over so the lip holds it up off the cam, and cut it to where the breather would hold it in place. that way it will keep the oil from coming up and possibly losing pressure like some guys say and other guys say it doesn’t matter! but I figure it’s a real EZ thing to do...so I’m gonna try it.
    Adjustments.JPG Adjustments.JPG Adjustments.JPG Adjustments.JPG Adjustments.JPG
  22. 33Doll
    33Doll
    Well after the “Howells” debacle, I ended up getting a SAR gas tank cover and they shipped it the next day! It’s stock without a recess but oh well I kind of actually I’m glad now and it was way cheaper!
    Also on a good note I got my gas tank back from my old school radiator shop guy! He boiled it, cleaned it Red-Koted it! and even painted it for me! What a guy!
    shout out to Chris at Auburn Radiator!
    Stogy, kidcampbell71, brEad and 6 others like this.
  23. 33Doll
    33Doll
    Well I measured the axle again for the 50th time just to make sure that it is the correct length again!
    And I ordered the correct ones from Dutchman axles!
    And it is because they said
    Better make sure it’s right....because
    “That’s an expensive pair of boat anchors if you don’t get the measurements right”!
    It’s all good I’m happy!
  24. woodiewagon46
    woodiewagon46
    from New York
    Doll, I did the same thing when I was building my cars. I liked going over to my cabinet and pulling out a part and not having to wait for it from UPS. One word of caution though, if you order something from Rock Auto, it is impossible to return it after 30 days, even if the part is defective. I learned the hard way.
  25. 33Doll
    33Doll
    Thats the new stuff on the floor, I put the new axles in the new diff, and went and measured the old one still in the car
    chryslerfan55, brEad and loudbang like this.
  26. 33Doll
    33Doll
    Looks like the SW sending unit is still good
    Got a cool Art-Deco heater in an ebay auction
    And My SAR Tank cover, looks beautiful! Its a United Pacific Though.
    I thought Steves had there own stamps?
    Maybe they sold them? Hope it fits as good as it looks! (Might just hang it on the wall) IMG_0696.JPG IMG_0697.JPG IMG_0698.JPG IMG_0699.JPG IMG_0695.JPG IMG_0700.JPG
  27. 33Doll
    33Doll
    What are the Odds! I scored a 33 sedan rear seat that’s covered nice!
    The guy was updating his seats, and I just happen to have a 33 that needs them check out my seats 500 bucks?
    Can’t even get new springs for that!
    New One:
    Old one: “Yum!”
    brEad, Stogy, loudbang and 4 others like this.
  28. milosmith
    milosmith
    That's serendipity for sure!
  29. 33Doll
    33Doll
  30. loudbang
