Projects 33 Doll Build Page
Discussion in 'Traditional Hot Rods' started by 33Doll, Mar 20, 2020.
  1. Stogy
    Stogy
    Is there a chance the shoes are so far from the drum that they are pushing out way to far to reach it? Therefore it may be an adjustment issue...
    In normal conditions there is very little space between the shoe face and the drum when all is operating as normal...I think...with my limited knowledge when the drum is on and pre adjusted before the auto adjust kicks in maybe it's giving the impression it's there but perhaps it's not...thats what I'm getting at...
    Stogy the fly on the wall eh...:D
  2. RICH B
    RICH B
    Does the shoe retainer plate sit over the pilot and flat against the anchor pin when there are no springs installed? Is there a possibility that something is machined wrong. The plate should fit relatively snugly on the pilot and the springs should hold the plate in tight. The pilot may not be as deep as in the attached picture. I've put hundreds of brake ***emblies together and I don't believe I have ever seen the retainer not sit flat when the springs were installed.
    For what it's worth Bendix specified that the primary (front shoe) spring be installed first.
    Stogy likes this.
  3. 33Doll
    33Doll
    It does have that pilot like the right there… I think these pictures are what you sent me Wayback when I was putting them together I just noticed that your brake shoes have the extra reinforcement that makes it sit flat and closer against that spring washer.
    Maybe I need the machine some kind of Spacer to go right there. IMG_1007.jpeg IMG_1017.jpeg
    Stogy likes this.
  4. 33Doll
    33Doll
    refurbished my 40 Ford brakes just in case I get sick of playing with this!
  5. dwollam
    dwollam
    Those are '46-'48 brakes. Main difference is the non adjustable lower pivots.
    Dave
    Stogy likes this.
  6. 33Doll
    33Doll
    Oh, that makes sense now I have 46-48 spindles on there too! (Square)
    I just like them because they’re simple but I was hoping that the Lincoln ones would work out but at least I have back up
  7. RICH B
    RICH B
    @33Doll Those shoes with the reinforcements are F-250.
    If you do add spacers, make them the same shape as the original shoe retainers other than a larger center hole.
    Still can't understand how the shoes could get so far out of place within the confined ID of the drum.
    brEad and Stogy like this.
  8. 33Doll
    33Doll
    That’s what I say!
    My friend let me borrow a brake and drum gauge I can figure the sizes for sure at least
    What about a spacer behind the anchor pin to push it forward?
    Outback and Stogy like this.
  9. Johnboy34
    Johnboy34
    from Seattle,Wa
  10. 33Doll
    33Doll
    Good morning Rich!
    I was wondering if you could do me a big favor if you have time?
    Can you measure the dimensions of that weird washer behind the springs, because mine is still on the car, and I’m at work and I want to make two of those today.
    And also, can you measure the big part of the pin p*** that step so I can know what size hole to make if you have time? Thanks, Rick.
  11. 33Doll
    33Doll
    IMG_1010.jpeg IMG_1012.jpeg IMG_1013.jpeg IMG_1011.jpeg You know… The more I think about it and look at the F 100 brake spacer that I put on the back…maybe it’s limiting the anchor pin adjustment? It looks like it is slightly narrower in the slot, and the OD is near the stamped area.
    The instructions say only use a spacer for the one and three-quarter brakes.
    but I think that just pushes the pin out a little where it goes through. Like maybe it stops on the threaded part to push it out? I don’t have one so I don’t know?
    well, that’s easy enough to just take off readjust the anchor pin.
    Maybe I screwed myself trying to think my method is better than theirs?
    I just didn’t like the idea of putting a lock-washer straight on the back of that plate, digging in.
    Jim Bouchard and Stogy like this.
  12. Stogy
    Stogy
    Was that meant for the inside? I think yes but only on a certain shoe which isn't yours, correct....
    You could use a washer instead of a lock washer behind the nut...turn it down and use some lock***e...
    As you said...there's definitely some play in that hole...up and down not side to side...with the spacer inside there would be more play/adjustment or does that special washer align it inside...
    Jim Bouchard and 33Doll like this.
  13. 33Doll
    33Doll
    I can’t remember if it was inside or outside, but it was off of 53 to 56 f100 backing plates
  14. Stogy
    Stogy
    Jim Bouchard likes this.
  15. Stogy
    Stogy
    Quoted below from the Thread Johnboy shared...is that anchor/pivot eccentric? Just another what if...
    "Your 'anchor' bolt is upside down. The anchor bolt is at the top and it is cam shaped, if you flip it over it'll raise the brakeshoe mounting up (right now it is down), the other visual clue is the pins from the master cylinder and going downhill, they'll be level when you flip the anchor over. When you take it back out look closely at it and you'll see what I mean."
    Algoma56 and Jim Bouchard like this.
  16. RICH B
    RICH B
    @Stogy I added a couple pictures.
    The reinforcing washer with the square edged hole (??-2029) normally goes on the back side of the backing plate. While I can't speak for Boling Bros' anchor pin, the flat sides of original anchor pins extend thru the backing plate and engage with that washer.
    Outback, 33Doll and Stogy like this.
  17. Stogy
    Stogy
    Looking at the inside I can't see that washer going anywhere but outside either but is its orientation outside specific...it seems elongated or it just camera trickorey...
  18. Stogy
    Stogy
    33, you're right with 2" brakes no spacer washer is nessesary and I note the squared part of the pin is not protruding out of the backing plate on yours hence they say that is not needed so you technically used it for a washer...and it may have affected adjustment?
    I also note when installing they say not to tighten when initially installed but don't explain why really...adjustment maybe then tighten?
    33Doll likes this.
  19. 33Doll
    33Doll
    these I am making new ones like you said yesterday, I wanted to know the dimensions, and the pin size to make the hole bigger like you said, because mine are still on the car and I’m at work. I have a drill press and stuff here so I was gonna make them.
    I kind a roughly, no image wise in my head, but if you could measure the actual spring retainer ?
    The F1 hundred washer, is something different. That could be causing problems IMG_1029.jpeg IMG_1007.jpeg
  20. RICH B
    RICH B
    Sure.
  21. 33Doll
    33Doll
  22. Stogy
    Stogy
    @RICH B thanks for the extra pics...that shows similarly to Boling's pics...square protruding thru backing plate...perhaps they must also have used the 1 3/4" shoes nessesitating the special washer you show too...
    33's setup shows that square not protruding the backing plate...
  23. Stogy
    Stogy
    Step 8 is where the tightening of the anchor pin nut is mentioned...a**** of other important details in adjustment...
    33 again there's enough bolt on that pin to add a washer the same dia as the lock washer...but it seems there's definitely a reason and self alignment that must happen before that is tightened for good...
    Another question...how is the other side? No issues?​
  24. 33Doll
    33Doll
    Stogy and Jim Bouchard like this.
  25. 33Doll
    33Doll
    The other side is OK so I was going to try to swap the shoes from that side and see what happens. Was also going to try to swap drums first, but I’m pretty sure it’s the shoes.
  26. 33Doll
    33Doll
    Yeah I know I kind a remember. My F1 hundred and stuck through and that washer was on the back. I was just trying to use it as a flat washer since the boiling brothers one doesn’t go all the way through, I was just thinking that maybe it’s too big in diameter to allow the pin to go up far enough?
    I have some M 14 mm washers that should have a big enough hole in a small enough diameter to be able to allow the pin to still move.
  27. RICH B
    RICH B
    Step 2 of Boling Bros directions makes absolutely no sense.
    Concerning the spring here are a couple pictures of the manual specifying which is first. May be something to it as they bolden and repeat it several times.
    Jim Bouchard, Stogy and 33Doll like this.
  28. 33Doll
    33Doll
    I would trust manual-over the boiling brothers guys ahyhow.
    That’s how I’m gonna do it next time primary is long shoe, right?
    come to think of it that’s why I put that space are there in the first place because those instructions are so stupid on step number 2! Those guys won’t answer me by the way!!!
  29. Stogy
    Stogy
    Its a shame when a company makes a great product but won't update stuff that doesn't support proper function...this stuff is potentially life threatening really...it shouldn't be left to customers and their installers to figure it out...a change to instructions with an apology for inconvenience would go along way...but here we are...:oops:
  30. RICH B
    RICH B
    Primary shoe is the short one and goes toward the front of the car.
    Outback, Jim Bouchard, 33Doll and 3 others like this.
