Projects 33 Ford 3 window- Saving it from street rod hell!!!
Discussion in 'Traditional Hot Rods' started by el Roach, Nov 30, 2016.
  1. el Roach
    el Roach
    20161130_062240_001.jpg 20161130_062340.jpg 20161130_062349.jpg 20161130_062405.jpg Here is my newest acquisition. 33 Ford 3 window, all steel, chopped, channeled, built in the 80's.
    The car had been in the June of 86 Street Rodder mag in a little different form. Plans at this point are to get rid of the coil overs in front and fix the bodywork in the rear that's been butchered. Other changes like grille and wheels & tires will come later.The car has new black and white tuck and roll in it, which is a plus.
  2. Rex_A_Lott
    Rex_A_Lott
    Sounds like a good plan, enjoy. Nice car. Good Luck
  3. figure8
    figure8
    See that the cowl vent and a couple of door hinges are missing. Chop looks great in the pictures. Does the windshield still crank out?
  4. Jalopy Joker
    Jalopy Joker
    Congrats - look forward to changes
    el Roach likes this.
  5. Funny how word travels fast. Just herd about this yesterday!
  6. Squablow
    Squablow
    Looks like a mostly high quality car with some bad styling decisions, I think once you're done doing your planned changes this will be a really great car without having to undo everything. I like the plan.
  7. brady1929
    brady1929
    Looking forward to you making it look better.
  8. el Roach
    el Roach
    Chop is nice and you're right about the cowl vent and door hinges. Unfortunately, the window does not crank out.
    **** Riley, I just got it home last night!!! Rumor mill is FAST!!!
    Yea, the car is really well built. It's a good platform to start with.
    Don't think I'm going to mess with trying to get the cowl vent back in place. We'll see.
    The front end and wheel/tire combo will definitely be changed.
    IT'S ONLY TIME AND MONEY !!!! :eek::eek::eek:
    AHotRod likes this.
  9. A Boner
    A Boner
    Looks like with a few tweets, you will end up with a very slick traditional looking street rod!
    ...................................TWEAKS
  10. swifty
    swifty
    At least they chromed the windshield frame. That's a very long hood on there. Did they lengthen the frame instead of recessing the firewall? You've got a lot of work to do on that rear pan. An original grill will help that a lot.
  11. woodiewagon46
    woodiewagon46
    from New York
    You might want to do away with the single chamber master cylinder also.
  12. mike bowling
    mike bowling
    Please!!! Make the billet and shiney stuff go away! AHHHHHHHH!
    It is a nice car, and it WILL be nicer, just needs a major "tone down".
    .02 worth
  13. dumprat
    dumprat
    from b.c.
    Why does the hood look so long?
  14. el Roach
    el Roach
  15. el Roach
    el Roach
    Whoa, how did I do that?
  16. ^ X2
  17. el Roach
    el Roach
    The hood is longer partially because of the design of the aftermarket grille. Picture makes it look worse than it is. I'm going to be doing away with the hood latch mechanism too.
    AHotRod likes this.
  18. dumprat
    dumprat
    from b.c.
    Cool. You get rid of a bunch of junk it should be a nice car.
  19. AHotRod
    AHotRod
    It's a beauty !
    Looking forward to seeing your updates and changes that are coming.
  20. Rocky
    Rocky
    Classified Editor
    Make it yours.
  21. junkyardjeff
    junkyardjeff
    A good winter project.
  22. Gary Addcox
    Gary Addcox
    Personally, I am a streetrodder, but I agree with you, Bud. A transverse spring up front and some m***aging out back would do that ride some good. Good luck.
  23. Gary Addcox
    Gary Addcox
    I think I see a tube axle with hairpins. If that is correct, you would do yourself a favor by replacing said axle with an I-beam. The present setup is way too rigid to ever get a smooth ride, that is, the smoothest ride that can be had with split "bones", er, hairpins.
  24. Xman
    Xman
    Lookin forward to see how this comes out. Good luck, nice car to start with!
  25. el Roach
    el Roach
    Yea the whole front end will probably be replaced at some point.
    Thanks Xman! If I could make it look like your coupe I'd be in "hot rod heaven"!!!
  26. el Roach
    el Roach
    No disrespect meant to anyone Gary, but I am more of a traditional rodder that likes rods of different era's. When I built my 32 roadster, I built it like I think someone could have done in 1958. My 34 5-window coupe was done close to a 1949 build. I hope to take this car back to a late 50's time.
    kidcampbell71 likes this.
  27. The37Kid
    The37Kid
    Nice car, at first glance I thought it had IFS, how does that setup ride? Bob
  28. el Roach
    el Roach
    No IFS Bob. It's and old Superbell tube axle with coil-overs. Rides good, but I just can't deal with the look of it.
    I'll be putting on a dropped 34 axle with transverse spring.
    Squablow likes this.
  29. Congrats on obtaining a steel 33 in any form -let alone one that runs and drives- sounds like you are on the right path with a good plan!
    Late to the Party and el Roach like this.
  30. low budget
    low budget
    from Central Ky
    Of course I remember the ZZ top car but I also remember a fenderless red coupe with wider lower profile tires on all 4 corners too in a 80s mag feature. Got any mag pics?
