33 ford motor options
Discussion in 'The Hokey Ass Message Board' started by 53 ford, Oct 27, 2012.
  1. 53 ford
    53 ford
    I want to replace my motor but I don't want to cut the firewall. I've found a 215 buick, will it shoehorn in? Will any old dodge or desoto hemi fit?
  2. Normbc9
    Normbc9
    Here is one with a small block V-8, 700R-4 and a Quick Change rear. It takes planning but it all fit. The steering and radiator do take some shoe horn work.
    This car is in Prescott, AZ and has a great reputation for being well done by a craftsman/owner.
    Normbc9
  3. metal man
    metal man
    That's not even close to being a Ford body. It's one of those kit deals. Not really any comparison.
  4. Don's Hot Rods
    Don's Hot Rods
    from florida
  5. 53 ford
    53 ford
    Don, looks like it has already gone to hell. All I wanted to know is will a 62 buick motor fit without cutting the firewall.
  6. Don's Hot Rods
    Don's Hot Rods
    from florida
    Here is a chart with all the most popular engine dimensions.
    http://www.carnut.com/specs/engdim.html
    I'm surprised that the 215 is almost as long as a sbc motor. Maybe the water pump and timing cover stick out somewhat, making it that long. I know a lot of guys put the 215 into MGB's, which led me to believe they are compact.
    Aren't the Rover engines a 215 Buick also ? What is your reason for choosing this particular motor ?
    I found this one on Youtube, it really doesn't look very big in this trike.
    http://www.youtube.com/watch?v=UzA5-OTktw0&feature=related
    Don
  7. metal man
    metal man
    I wish I knew the answer to the question, but the Dodge is the only Hemi I've not built a car around, and never messed with a 215. There has to be a few build threads on here with a 241 Hemi, right?
    I can measure the length of my Desoto Hemi if it helps you. Too bad the Chrysler is the only Hemi on Don's chart.
  8. metal man
    metal man
    I don't know how to post a link, but look at a thread ***led "hot rodding a Buick 215". There is a good photo there of a 215 in a '33 Ford. Belongs to a HAMBer in Australia.
    It appears to have an uncut firewall.
  9. metal man
    metal man
    Here you go.
  10. If you are fitting a 215 it can be done without cutting the firewall, but is tight.
    To give you some extra room swap in the short water pump from a mid 90,s Range Rover (the engine is the same as the early 215)- this gives you about an extra 1.5" to play with.
    David
  11. Mnhotrodbuilder
    Mnhotrodbuilder
    from Afton, MN
    I have dimensions of the dodge and desoto hemis on my home computer but I am away from my comp right now. Off the top of my head the desoto hemi should fit.
  12. 53 ford
    53 ford
    Thanks for the help. I have found a 40 mercury flathead I think will work fine. Harley
