Technical 33 Ford pick up windshield gasket
Discussion in 'The Hokey Ass Message Board' started by 33FDPU, Dec 27, 2014.
  1. 33FDPU
    33FDPU
    can anyone tell me if there is a gasket that goes in the track (frame) on a 33 Ford Pickup. I believe 32, 33 and 34 closed cabs are all the same but I can't seem to find a gasket on line. only one I see is the one on the outside of the frame.
    I am hoping there is one that surrounds the window and fits in the track on the windshield frame.
    I have to replace mine and it was just put in with sealant. what a mess to clean out.
    THANK YOU for the ***istance
  2. Hotrodmyk
    Hotrodmyk
    Yes, there are seals that go in the "tracks" in the window frame. There is also a seal that goes on top in between the hinge and header. Check out suppliers like MAC's and Drake. Most of their catalogs show how they fit.
  3. 33FDPU
    33FDPU
    THANKS... I WILL CALL THEM MONDAY TO MAKE SURE I ORDER CORRECTLY.. I saw them on there but was not sure.
  4. Sounds like you are talking about the windshield setting tape.
  5. RICH B
    RICH B
    If you have access to a "real" gl*** guy, it might be worth your while to see him. He can tell if the gl*** is sized correctly for the frame (might not be if it was put in with sealer previously) and he will have the right size setting tape for your application.
  6. 33FDPU
    33FDPU
    we got gl*** from the local gl*** shop. he sized it to the old one... we stuck it in, sealed it up like they gl*** man told us and were closing the swing hinges and CRACK!!!
    so I am no sure who to believe other than yall who have done it.
    thanks again to all
  7. 325w
    325w
    That crack is not unusual. The frame twisted when you tried to close. You just have to be careful closing the swing out windshields.
    Just Gary likes this.
