Technical 33 ford PU firewall mounted booster?
Discussion in 'The Hokey Ass Message Board' started by alteredpilot, Jun 11, 2024.
  1. I'm trying to figger out a booster/master solution for brakes on this thing. Before anyone mentions it, No, I cannot mount it to the frame under the floor. Anyone have a recommendation for a vendor that supplies a solution for something like this, and/or maybe pics of your set up so I can get some ideas? Thanks in advance!
  2. If you have power steering, I would suggest hydroboost. What engine are you using?
  3. corvair steering
    350
  4. 34Phil
    34Phil
    7 or 8" dual diaphragm is small as you can get. sticks out 5-1/4". Check your clearances
  5. ekimneirbo
    ekimneirbo
    from Brooks Ky
    You might look for someone parting out a C4 Corvette and buy the master cylinder and booster from it. It's pretty compact .......... Maybe get the pedal and bracket ***y as well. Pedal ***y from mid-90s jeeps also are a consideration.
    alteredpilot likes this.
  6. 31 B'ville
    31 B'ville
    from SE Pa
    Maybe look at ECI brakes, they have boosted and manual firewall mount setups.
  7. treb11
    treb11
    Maybe a remote booster setup? A hydraulic booster is pedal actuated and plumbed to a remote slave cylinder/MC .(mounted anywhere)
  8. Anyone have any luck with a 90* under dash set up?
    Unkl Ian likes this.
  9. Bandit Billy
    Bandit Billy
    How are you going to fill the M/C? I have see guys with removeable cowls (A's) and I've seen guys use the cowl vent. But unless your truck has a lot more real estate under the dash than my 41, you aint putting a booster under there without a lot of re-engineering.
    Tim likes this.
  10. Bandit Billy
    Bandit Billy
    The firewall option is kinda fugly. And I can say that because I had to do it on the 41 PU I just finished. :cool: Hopefully you are running a hood cuz no one should have to look at these things on an old car or truck.
    I ran out of room under the floor between the RE46 transmission and exhaust pipes. But my wife required an automatic and power brakes so my options were rather limited. I figured if I have to look at it, it had better be chrome. I sourced the components from CPP, they are F body (Camaro) brackets, proportioning valve and dual bail M/C, with the small diameter booster.
    I chose the place on the firewall to allow removal of the hemi's rocker covers.
    I didn't just cut a hole in the firewall, I welded in bracing both on the outside and inside of the bulkhead to receive that unit. Another brace goes form the pedal drop to the dash. The M/C wasn't designed to go there, the firewall itself is not designed to support it. You have to account for and correct that.
    This is the pedal drop I used (universal fit, I think it was for a 55ish chevy PU).
    I added the brake light switch on an adjustable, telescopic arm (the short bracket) and welded in studs to secure the taller brace that runs to the column-drop bolts under the dash. These are both U channel for rigidity. It's job is twofold, brace the booster and give the column mount extra support.
    lemondana and bchctybob like this.
  11. 31 B'ville
    31 B'ville
    from SE Pa
    IMG_0923.jpeg IMG_0804.jpeg IMG_7420.jpeg I needed a firewall mount with booster also and went with the ECI setup with a 9” booster. The M/C with booster was hiding way too much of the engine so I built a bracket/ firewall brace to mount the booster inside the firewall behind the dash. I don’t mind seeing just the M/C on the firewall.
  12. okiedokie
    okiedokie
    from Ok
    For some bucks there are electric boosters.
  13. bchctybob
    bchctybob
    Not trying to be a smart *** but you shouldn't really need power brakes on a '33 pickup with a well thought out brake system. My '28 coupe had 4-wheel disc brakes and a Mustang M/C, stopped great. Customer car?
  14. Unkl Ian
    Unkl Ian
    Dodge Tradesman vans used them in the 70s.
  15. That's what I'm saying, but this guy is pretty insistent on a brake booster. Everything else is done.
    bchctybob likes this.
  16. krylon32
    krylon32
    from Nebraska
    Years back I did a few customer cars with fruit jar MC's and T Bird remote mount boosters. In this modern world it's kind of a step backwards but I never liked hanging all that booster stuff on the firewall of an old 30's car or truck.
  17. gene-koning
    gene-koning
    As mentioned, you have to weld thicker metal to the firewall (top to bottom and the entire driver's side), then brace it to the dash. Even then that may still be some firewall flex when you push on the brake pedal.
    The only brake booster I've seen fail in short order are those small 7" or 8" boosters. I would go with the proper diameter bore master cylinder with the proper brake pedal ratio and skip the booster. Wilwood has great information on how to size the master cylinder bore.
