33 ford spring perch bolts
Discussion in 'The Hokey Ass Message Board' started by 1time, Oct 27, 2010.
  1. 1time
    1time
    from minnesota
    I need some advice on a problem i'm having with the spring perch bolts on the front axle of a 33 ford, everything is un bolted but i cant get them out of the axle, is it ok to heat them if so do i heat the bolt or the axle, I'm trying to save the wish bone to be reused, if i heat the wishbone will it make it brittle, any help would be greatly appreciated Thanks
  2. F&J
    F&J
