Some of you have seen this before, it's a father/son/grandson project deal. Well grandfather is moving to a retirement place. Grandson hasn't worked on truck for a year or more. And dad(me) has been paying for everything. So it's a steel body. 3 3/4 chop , one UP door ($1800) needs 1 lower cowl patch and bottom inch across back of cab. Bed is shortened to center the wheel well. Hand made tailgate. Have a steel 34 hood,34 grille, 1 set of rough steel fenders that I don't think fit the truck. 1 set of 32 glass fenders, 1 glass 32 grill. White oak for bed.great windshield frame. The frame is repro 32 rails,split bones,posies spring,tube shocks, 37-41 axle ,round backs with new kingpins,repro vega box with new tie rods. The rear is parallel leafs, tube shocks,9" 28spl with 4.11s. Brakes are all new f100 in frt and bronco rear,only the baking plates are used.firewall mast cylinder and frame mounted prop valve. I have a boxes of small parts. THE ENGINE and SHIFTER IS NOT INCLUDED!!!!!!!!!!!!!you will get the th350 trans, sac headers and stainless exhaust. , Text or call me at 484 429 4904 , I only check computer once a day . MUST SELL BY JULY 15th or it gets stored again.
