Technical '33 roof insert
Discussion in 'Traditional Hot Rods' started by TCTND, Jan 14, 2021.
  1. TCTND
    TCTND
    The roof of my '33 5win has a groove formed around the periphery within which is a separate channel that once held the "fibrous material" into which tacks were driven. Does anyone know if this channel is attached solely by the rivets that also held the aforementioned material or if it is also spot welded in? Mine was potted sometime in the past with some god-awful rock hard, indestructible filler. I'd like to grind off the rivets from the underside and pry the whole channel out, but I don't want to tweek the actual roof doing it.
    regards,
    Phil
  2. alchemy
    alchemy
    Pretty sure there was no spot welding of the tack strip to the tin.
  3. cornfield county
    cornfield county
    from Indiana
  4. Johnboy34
    Johnboy34
    from Seattle,Wa
    And the factory tar like sealer it's embedded in loosens with heat. I used a heat gun under the channel.
    Sent from my SM-G973U using The H.A.M.B. mobile app
  5. nochop
    nochop
    from norcal
    We wanna see....
  6. TCTND
    TCTND
    Thanks all. Confirmed there are no spot welds. It's really tedious grinding each rivet, exposing the top enough to grip it then working it out, but it can be done without damaging anything. Will post pics when complete.
    regards,
    Phil
