Projects 33 truck dash into 28 model a?
Discussion in 'Traditional Hot Rods' started by manitouguy, May 16, 2021.
  1. manitouguy
    manitouguy
    Hi all, I am considering putting a 33 truck dash into my 28 Model A (moving fuel tank to trunk) and curious if anyone can tell me what the width difference or issues might be?
    I am in the process of trying to confirm the width to see if I will have to trim down or not - and will search the forum further to see if I can find the info but any opinions or experience very much appreciate it in advance
    thank you
  2. Fordors
    Fordors
    The width of a ‘32 Pickup dash is
    41 5/16” and the ‘33 will be the same AFAIK.
  3. manitouguy
    manitouguy
    Thanks - so I suspect the 33 dash will be wider - how much I wonder? Can’t get to my A for a few days to check
    If I have to narrow it I wonder if I can trim the ends rather than going through the center of the 33 dash
  4. sloppy jalopies
    sloppy jalopies
    Did that... memory says the A was about 3/8" narrower on each end... think it did not interfere with the mounting screw holes on the '32 truck dash...
    25 years ago ?...
    i have one of each, if you need i can measure, but the top cross rails are wider than the bottom edges...
  5. manitouguy
    manitouguy
    Thanks very much guys, my buddy right in the shop where I’m working on my car has a roadster with a 33 – in it and I totally forgot.!
    he sent me a couple of pictures today running a tape across the width of each
    as mentioned above the 33 Dash came in at about 41 inches and a quarter and yes sloppy it appears like the Model A dash is about a half inch or so shorter on each end - so with some minor adjustment I think it will fit quite nicely
    really appreciate the feedback guys thanks again
  6. sloppy jalopies
    sloppy jalopies
    can't help myself... measured with the tape lying on the dash's top rail...
    sort of in a radius...
    a '30-'31 dash rail is 41.5" wide...
    '28-'29s are 41.75"...
    a gl*** '32 3 window is 42" ...
