Technical 33 tudor sedan
Discussion in 'Traditional Hot Rods' started by clyde28075, Oct 3, 2015.
  1. clyde28075
    clyde28075
    from concord NC
    Need some help here guys i have a 33 tudor sedan on a 33 ch***is if im running fenders how wide does the rear housing flange to flange on a speedway 55" 56" 57" Or in a Currie rear housing axle face to axel face they say there stock width is 56 " face to face will this width work let me know what you think also i think it should be centered is that correct
    THANK YOU
  2. Jalopy Joker
    Jalopy Joker
  3. Nailhead Jason
    Nailhead Jason
    56 inches wide should be just about right. I have a 55.5 in wide 9 inch under the 32 sedan we have been building. Thats wheel mounting surface to wheel mounting surface. I always figure out what wheels and tire size i want to run first and then i can figure a final axle width. You way be able to go a little narrower if you wanted to use a deep dish wheel but i would check clearence in the inner wheel well.
  4. 3banjos
    3banjos
    from NZ
    56 1/2" on the 34. 4" back space rims.
  5. Pewsplace
    Pewsplace
    I run a 57 Ford 9" - 57.25 - using 8" rims with a 3 1/2" backspace and a 225 x75 tire. Most shops sell the 56" as standard and they fit about all early Fords.
  6. krylon32
    krylon32
    from Nebraska
    90% of the 28/34 ch***is done in my shop use the 56 outside width rear with big bearings and late Torino ends, Currie/Johns/and Winters. That is a 51 inch end to end housing with the axles having a 2.50 bearing offset for either drums or discs.
  7. clyde28075
    clyde28075
    from concord NC
    Im here please tell me what you think
  8. clyde28075
    clyde28075
    from concord NC
    Thank you for your help would you happen to know what size diameter tire i could fit under the fenders is 28 or 28.5 to tall tire
  9. clyde28075
    clyde28075
    from concord NC
    Thank you for your input
  10. krylon32
    krylon32
    from Nebraska
    I've had several customers use 255/70 R15 BFGs on 8 inch rims. 29 inches tall
  11. clyde28075
    clyde28075
    from concord NC
    thank you for your help
  12. clyde28075
    clyde28075
    from concord NC
    Wow thats great i didn't think i could go that tall with fenders but that is a great size i would like to use that thank you very much for that and the rear width Information its my first build and i'm kind of doing it in stages as my money runs out so i'm trying to get the ch***is built without buying all the finish accessories that i don't need yet so i can get ch***is built that's why so many Questions Again thank you
  13. clyde28075
    clyde28075
    from concord NC
    What size wheels and tires are you using PLEASE ?
  14. clyde28075
    clyde28075
    from concord NC
    Forgot one thing should the rear housing be centered ?
  15. rusty rocket
    rusty rocket
    DSC02123.JPG I'm running a 255 in my 32 sedan. It fills the rear fender up nicely. I would think the same would work on a 33-34
  16. krylon32
    krylon32
    from Nebraska
    You can run the housing centered or pinion centered. I use housing centered rears as about half of what I do is triangulated 4 bar and they mount a little easier on a housing centered rear. I've done lots of ladder bar rear ends with pinion centered rears.
  17. 3banjos
    3banjos
    from NZ
    Definitely center the housing. Just looks right.
  18. rusty rocket
    rusty rocket
    Your doing a full fendered car so it really doesnt matter if you center the housing. your not going to see it.
  19. clyde28075
    clyde28075
    from concord NC
    Thanks for your help
  20. clyde28075
    clyde28075
    from concord NC
    THANK YOU for your help I Appreciate it
  21. clyde28075
    clyde28075
    from concord NC
    Thank YOU for your Help I do Appreciate it
  22. clyde28075
    clyde28075
    from concord NC
    Boy She is coming along Nicely Looks Awesome
  23. Nailhead Jason
    Nailhead Jason
    255 70 15 on an 8 inch steely with 4 inch back spacing.
  24. Nailhead Jason
    Nailhead Jason
    ^^^^Not really sure how tgat got quoted. Stupid cell phone and stupid operator!
  25. Larry W
    Larry W
    from kansas
    Get the wheels and tires you want. Set them under your car. Adjust to the fit you want.
    Measure distance of mounting surface. now you have the width of the rear end
  26. Johnboy34
    Johnboy34
    from Seattle,Wa
    On my 34 tudor I have 55" wms to wms with 235x70x16, (a little smaller width, same hight than 255x70x15) 8" wheels-4" back space and had to do a mild tub job to make them fit. Bought tires and wheels first, ordered a rear and made them fit. The 8" Maverick rear (56" i think) would have worked with different offset wheels. ^^^^^ like he said, John
    [​IMG][​IMG]
