Technical 33 WILLYS coupe project
Discussion in 'Traditional Hot Rods' started by axel's40, Jun 21, 2023.
  1. axel's40
    axel's40
    Just picked up 33 willys gl*** project car (roller) from a guy retiring from hot rodding and having a hard time finding the gl*** rubber seals for the front, rear, and opera windows. Gotta be something out there. Googled the hell out of it and called a few places but to no avail. Guessing will have to get some universal seal?
    chevy57dude and chryslerfan55 like this.
  2. jeepster
    jeepster
    from wisconsin
    Always loved the look of the '33.
  3. In_The_Pink
    In_The_Pink
    Same here. Too bad the Model 99 never came to be.
    I think so. You'd have to go in knowing what the original (or at least close) seal profile(s) was(were), but I bet Metro Molded Rubber would have something by the foot which would work for you.
  4. axel's40
    axel's40
    thanks for your info... i'll check out Metro.
  5. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I'll bite.
    What was the Model 99 and why did it never come to be?
    EDIT: I couldn't wait. I Googled it and learned the 99 was a stretched, widened 77 with a six banger. Personally, I think it is not nearly as graceful as the 77. (The bankruptcy court killed the 99.)
  6. In_The_Pink
    In_The_Pink
  7. axel's40
    axel's40
    That should give me enough options. Thanks
  8. I am also building a 33 Willys Model 77 Coupe. I am almost finished with it. My
    car is a Willys Unlimited body that I bought in 2003. It was on the back burner
    until 3 years ago when I really started to work on it full time. You did not say
    what brand body you have. Now to your gl*** problem. On my car I put the
    windshield in like a modern car, Bonded in with 3M Windshield Adhesive .
    I am making a polished frame for the outside so it will look stock. The quarter
    windows & backlight are bonded in from the inside with a painted garnish to
    finish the inside edge. Depending on how your body is made, you may be able
    to do the same with out using a rubber gasket. My car is chopped & I need all
    the gl*** area. Feel free to contact me if you have questions, Jerry from N. C.
    panhead_pete likes this.
  9. hemihotrod66
    hemihotrod66
    Did you try a place called Willys Replacement Parts....They maybe able to help....
  10. choptop40
    choptop40
    Thats bad *** big time....good luck and post the build...
  11. lake_harley
    lake_harley
  12. JohnLewis
    JohnLewis
  13. willys36
    willys36
    The Model 77 doesn't use cl***ic shaped window gl*** channel molding. In building my '35 coupe I used rubber strips about 5/8" wide and about 1/8" thick. This is what was on the windows when I tore down the car back in the day. I don't know about 'gl*** reproductions but my guess they are built to use the same system as the steel originals.
    Here are a couple options
    https://metrommp.com/adhesive_backed_campertopper_seal_lp_11425/
    https://www.steelerubber.com/sponge-rubber-extrusion-70-4205-99#70-4205-99
  14. Supposedly there were 3 model 99 Willys built. I heard years ago that someone in Maryland had one of the three. Over the years, I have had 3 model 99 headlight lenses and rims. If you want verification that the rims and lenses existed, contact Don Axlerod, hdlthqtrs@aol.com.
  15. axel's40
    axel's40
    The body was from Heritage Hot Rods in Illinois. Steele didn't have anything. Couple other manufacturer's had a couple possibilities , but will know more when it's in the shop. I should be able to find something from all the help and answers i've gotten. Thanks to all.
  16. 33 fuel
    33 fuel
    looks like a cool build ... What motor?
  17. willys36
    willys36
    Pretty sure flat rubber strips is the answer.
