331 Caddy header flanges?
Discussion in 'The Hokey Ass Message Board' started by scoop, Sep 25, 2006.
  1. 81ttopcoupe
    81ttopcoupe
    from Cedar Park
    I'll take a pair if they fit the '53 331. What year heads were the patterns made from, or what years have they been know to fit?
    When and where with the $35?
    Any plans for intake flanges? I would love to build my own log intake.
  2. breeder
    breeder
    if they fit the 62 390, then im all about it!! letme know .......:)
  3. TORR
    TORR
    from BOSTON, MA
    I gave some bad (not specific enough) info here earlier...
    The exhaust bolt holes will line up on all the 49-62 motors, they stay the same as far as spacing goes... But the exhaust port sizes grew much larger on the 365-390's. {I also remember there being an increase around 1952/53? on the 331's?} The width of the exhaust ports are almost identical from 331ci to 390ci, however, the height of the middle ports increased by a little more than a 1/4" and the side ports height increased by almost a 1/2". The later exhaust manifolds will not swap onto some 331 heads without some modification, you will see some daylight in the size difference. I could go on here, but this isn't answering the question at hand.
    The question I believe was will the 331 flanges work on the 365/390 mills.
    They will line up bolt hole wise, but you will need to ("you should") remove approx 1/4" to 1/2" of the flange material to get the ideal flow. Bolt them on your heads, and die grind accordingly.
    As long as these flanges are made with some extra meat on them for porting height wise they should work fine.
    With that said, I would also be interested in a set if you make them.
    -Torr
  4. scoop
    scoop
  5. scoop
    scoop
    UPDATE: Did a trial cut today had to make some changes to the program and went down to 5/16" material due to warpage.Doing another trial cut tomorrow to see how they look. I'm sending the first set to Evel for test fitting if they work I will be sending out the rest of the orders.If 5/16" don't work for you let me know and I'll refund your cash.Thanks for being patient,it's crazy at work and I'm just another customer so I have to wait in line too.
  6. Is it too late to get in on this? :beg:
    PM me and ill get dollars in the mail tomorrow.
    I have a '55 331.
  7. LongnLow
    LongnLow
    I'll take a set if it's not too late. let me know where to send the bones.
    '54 331
    thanks.
  8. Southfork
    Southfork
    Hey, I'd like top get a set too, if I can. Please PM me with where to send the $.
    -Southfork
  9. scoop
    scoop
    UPDATE:I hope to be sending out all the orders by the end on the week.Our programmer made a error otherwise they would have been sent out yesterday(Mon).Looks like there might have to be some modification made around the dipstick but it should'nt be too much of a problem.Sorry for the wait!
    Scoop
  10. InDaShop
    InDaShop
    from Houston
    How did the 5/16"s turn out? I made a run of some different flanges in 3/8"s because thats what we had, and they came out like a turd in a punch bowl.
    Way too thick IMO.
    I was thinking 1/4"
    How thick are the ePay ones?
  11. HEATHEN
    HEATHEN
    from SIDNEY, NY
    For what it's worth, the old speed equipment catalogs list three different part numbers for Cadillac flanges: '49-'51, '52-'55, and '56-'62. I've got a set of Belond headers that must have been intended for '49-'51, because they're quite small.
  12. scoop
    scoop
    5/16 came out good. Had some of the same problems with the 3/8 too.
  13. seabeecmc
    seabeecmc
  14. scoop
    scoop
    Ran into few glitches,then the torch went down,hoping to get them fixed next week.I'm really sorry for the delay.If any of you guys want a refund let me know.
  15. LongnLow
    LongnLow
    no problem-just keep us posted.
  16. Hanksville Hot Rods
    Hanksville Hot Rods
    Alliance Vendor
    from Denver-ish
    Just curious, how are you cuttin these and how are they warping? I work with alot of 3/8" flanges since IMO they warp less when welding (I think when welding, 1/4" is way too thin especially on engines where the middle 2 cylinders are close, like SBCs and Y-blocks).
    Hank
  17. scoop
    scoop
    Warped in some of the areas around the ports and bolt holes.I'm cutting with a high def plasma,we've been having some problems with the torch lately so maybe that was causing the problems.Do you sell just the mandrel bent pipes?
  18. Hanksville Hot Rods
    Hanksville Hot Rods
    Alliance Vendor
    from Denver-ish
    I understand, some of the port designs don't leave room for much material. Yep, we sell bends; pm me or email me and let me know what you need.
    Hank
  19. scoop
    scoop
    I expect the flanges will be cut early next week,sorry for the delay this has been an adventure with these flanges to say the least.
  20. scoop
    scoop
    Started cutting today,I will be shipping Fri. and Sat.
    Merry Christmas and Happy New Year!!!
  21. notebooms
    notebooms
    Alliance Member
    scoop-- got these babies in the mail, and they look great. thanks a lot.
    -scott noteboom
  22. Hot Rod To Hell
    Hot Rod To Hell
    from Flint MI
    Ok, so now that these have been shipped out, has anyone compared them to the ports on a 365???
  23. Hot Rod To Hell
    Hot Rod To Hell
    from Flint MI
    Anybody???:confused:
  24. Dirty2
    Dirty2
    Are these for the smaller port 331 ?
