337 Flatheads
Discussion in 'The Hokey Ass Message Board' started by Vic, Jan 19, 2005.
  1. Vic
    Vic
    from Florida
    Any of you ever had any fun with a 337 Lincoln Flathead? I just picked up a '49 Lincoln Cosmo rag top and its the first BIG Flathead I've ever had. Before I start messin with it, I'd sure like to know some ins and outs.
  2. Dino
    Dino
    Cool car. Heavy engine. Can you post pics?
  3. Jive-Bomber
    Jive-Bomber
    MODERATOR
    Vic- as a guy who ran that motor in my 49 Cosmo coupe for years, I can tell you- Don't do it! Unless you have a ton of money to spend on it, and are o.k. with mediocre performance.
    Problem #1: The motor weighs 850 pounds
    Problem #2: Hop up parts are really rare, and cost $$$$
    Here's more about the engine: http://www.vanpeltsales.com/FH_web/flathead_specs-337bigV8.htm
    Hope this helps.
    jay
  4. Flynn's_57
    Flynn's_57
    from Nor*Cal
    Didn't germ swear by those motors or something??
    Or am I thinking "Y-blocks"?
  5. flatshoebox
    flatshoebox
    They ****! sell it to me [​IMG]...I need one really bad.. for an.......art project? yeah thats it! [​IMG]
  6. Henry Floored
    Henry Floored
    [ QUOTE ]
    [/ QUOTE ]
    Hey Vic,
    If we can find a spare stock intake, we can fool around with milling the top off and adapting a four barrel or something. Im not real familiar with the "big block" Flathead but I do know the the intake valves are larger than the 1.5" exhausts, maybe around 1.7" or so. The exhaust port boxes are smoother than the smaller Flatties. I'll bet you could get alot more ou'ta that baby by just uncorking her with headers a free flow exhaust and a wee bit more carburation. Let's play!
  7. Kustm52
    Kustm52
    I've got one, complete with trans, if anyone wants it...
    Brian
  8. Vic
    Vic
    from Florida
    Mike, I got the shop manual for the 337 yesterday. Also talked with Red at Red's Headers. He told me that a Cosmo is going to be at his shop in the next month, so he can fab a set of headers. Not sure about the X member or OD unit on ****** for room to run the exhaust pipe on the drivers side. I'll have to get under the car and see just how much room there is. You know me, I'm up for a Hot Rod Lincoln.
  9. Vic
    Vic
    from Florida
    I just got a digital camera. I'm better with flatheads. My wife (the computer pro) will have to set things up so I can try to post photos. I'll give it a shot.
  10. Henry Floored
    Henry Floored
    Don't think there'll be a problem with room. When it was on the trailer I crawled under it to hook up the tie downs and I got a good look at the m***ive X-member. The thing is the frame channel is so big that the typical lightening holes are huge by compareson to a frame like in your `39. Should be a snap to run duals and that Cosmo.
  11. flatshoebox
    flatshoebox
    [ QUOTE ]
    Brian
    [/ QUOTE ]
    OK!
  12. I havent even seen one speed part for a 337 anywhere (although Edmunds did make a 2x2 intake in '50 or '51) and Ive heard they cost a **** load to re-build. But if you can pull it off it sure would be cool! [​IMG]
    -Dean
  13. flatoz
    flatoz
    EVERYTHING
    worth doing costs $$$$
    thats why only the persistant dont end up with 350/350/9" hot rods!
    Hemi Joel likes this.
  14. Bruce Lancaster
    Bruce Lancaster
    Quite possibly the only source of rodding info on these things is the old "California Bill's Ford Speed Manual", available in reprint.
    I believe that a distributor with real advance mechanism was used on some early Lincoln versions, while Ford truck and later Lincolns got the Loadamatic. The good distributor would likely be a useful sart on improving this if you don't already have it.
  15. Jive-Bomber
    Jive-Bomber
    MODERATOR
    Just to clarify Vic-
    I'm not trying to poo poo the idea. I ran my Lincoln flattie for 5 or 6 years. It ran great, sounded killer, and never overheated.
    I'm just giving you a heads up if your on a budget- If money were no object, I might have kept the 337 after it needed a rebuild; It was just too expensive to consider at the time.
    jay
  16. Vic
    Vic
    from Florida
    As far as I can tell, the motor has been rebuilt some time in the last five or six years, and has seen little use. we fired her up and she ran fine. Have not driven her yet as there are several issues that need to be worked out first. I want to drop the gas tank and clean it and install a new fuel line, etc.
  17. wedgeii1
    wedgeii1
    from california
    So what happend?:confused:
  18. Blair
    Blair
    from xx
    there was one aluminum 337 head for sale on ebay made by edmunds that sold for $27 about a year ago. Good luck finding the other though....
  19. LIMEY
    LIMEY
  20. Dale Fairfax
    Dale Fairfax
    Check out austinrodshop.com. Ken Austin has been making multi-carb manifolds for these sweeties since 1953. Everybody puts them down because of their weight but I notice a lot of people jumping on the 346 Cadillac flathead bandwagon-it's gotta be near the same weight. Build a set of headers and lose 50#, Mill the stock heads, buy an Austin manifold, and go for it. You certainly won't see yourself (your motor) coming around every corner. Yes, Edmunds made both heads and manifolds for them but you'll probably never find them. Likewise the Edelbrock heads. Egge can provide O.S. pistons.
  21. Dale Fairfax
    Dale Fairfax
    Check out the more recent thread en***led "el8". It's got pictures of Ken Austin's beautiful '30 R.P.U. with the big Linc in it.
  22. Im with Flatoz on this one guys...
    I say if ya like it DO IT and to hell with the cost. If you dont build the ride you want, youre gonna end up hating it...so if a BB Flathead turns ya crank GO FOR IT !!
    Rat
  23. Henry Floored
    Henry Floored
    Man I think I'd try to reduce some rotating weight if this 337 is going in a light car. I'd investigate if an aluminum 8BA flywheel would bolt on (or make it work) with the lighter smaller clutch. That or adapt a tough little C4 automatic. The Lincoln 337 has a 4 3/8" stroke and produces plenty of low end torque so a lighter rotating ***embly should'nt hurt in anything less than a land yacht.
  24. homebrew
    homebrew
    Cubic $$$$$$$$$
  25. 2"
    2"
    Anyone have a picture of one of these engines? Preferably a Lincoln, but I'd settle for anything 337 ;)
  26. Jive-Bomber
    Jive-Bomber
    MODERATOR
    Here's the one in the Model A:
  27. 2"
    2"
    Cheers man.
    I like the look of that engine!
  28. KoppaK
    KoppaK
    Here's the one in Limeys clip
  29. ThingyM
    ThingyM
    There is a guy out here in the Orange county area that is building one to run at Bonneville. As I have heard, it will be 365 cu in'.. A friend of mine, Who is this guys neighbor,Said it Will be in a 32 roadster. Would it still run in the XR cl***????
  30. wedgeii1
    wedgeii1
    from california
    Here's mine and the Dodge it's going in.
